Topic: Arduino IDE Serial Port Gray/Grey (Read 3603 times) previous topic - next topic
DFTBA
I'm trying to use a Leonardo, and am trying to use the serial monitor for debugging, to make "trace" messages. When I click "Serial Monitor", it says the port is not found, and to change it in the Tools > Serial Port. Then, sometimes I can click it, sometimes I can't. When I can, nothing shows up (Programming?) When I can't, the menu is grey. Any help?
Osgeld
Two things
1) What OS?
2) Did you install the driver provided in the arduino software?
DFTBA
1) Windows 7
2) The software has previously worked. The only thing is that I've gotten a new Arduino board. Wouldn't the driver be the same?
Osgeld
Thats a good question, since I down own a Leonardo, but glancing in the driver folders (of 1.0, bit outdated on this computer), there is one specifically marked Leonardo
cmiyc
What do you mean when you say you got a new board?
Did you have a uno (or any 328 based) board and then you got a Leonardo?  Or you had a Leonardo and got a new Leonardo?  Where did you buy the "new" board from?
eried
If the problem happens on *some* times but not always, this probably will help you http://arduino.cc/forum/index.php/topic,118440.0.html
My website: http://ried.cl
DFTBA
I had a leonardo and got a new one.
DFTBA
I've now found that my board shipped with dead pins. If there is a defect here, might there also be one in the serial communication portion?
cmiyc
Damage is damage.  Something happened to the board that shouldn't have, so I would call the whole thing suspect.
