Loading...
Pages: [1]   Go Down
Author Topic: Wind Sensor Problem  (Read 509 times)
Cebu City
Offline Offline
Newbie
Hi im new to arduino!
View Profile
Hi i'm trying to make a Wind Sensor for my project and what i'm using as a wind sensor is a Microphone Module.
The problem is that when I blow into the Microphone it makes jammed sounds but sometimes it makes a consistent sounds only if I blow hard into it, how do I make a consistent reading so that it would not make jammed sounds?
Here is a video of my project.
And here is the code of my Microphone Module:
Code:
int senseMic = 0; //analog pin of gizduino //pin14
int speakerPin = 20; //analog pin of gizduino
void setup(){
void loop(){
  int val = analogRead(senseMic);
  //If Wind Is blown
  if (val > 540 || val < 490){
  tone(speakerPin, 277.180)
  //If Wind Is not blown
  else{
    noTone(speakerPin);
« Last Edit: January 07, 2013, 10:13:37 pm by xxryan1234 » Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
http://arduino.cc/forum/index.php/topic,140976.0/topicseen.html
Logged
Cebu City
Offline Offline
Newbie
View Profile
Here is the schematics of my Microphone Module
Logged
Cebu City
Offline Offline
Newbie
View Profile
So you are saying sir that I should use smoothing so that I can avoid this spiky sounds I hear?
Logged
Montreal
Offline Offline
Edison Member
View Profile
WWW
Exactly.  Mic outputs audio, about 20 Hz and up. To measure it, you need rectify and smooth it. Otherwise, as it jumps up and down there is a chance analogRead would measure when it crosses zero line.
Logged
Cebu City
Offline Offline
Newbie
View Profile
Code:
// Define the number of samples to keep track of.  The higher the number,
// the more the readings will be smoothed, but the slower the output will
// respond to the input.  Using a constant rather than a normal variable lets
// use this value to determine the size of the readings array.
const int numReadings = 10;
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
int speakerPin = 20; //analog pin of gizduino //pin14
int inputPin = 0; //analog pin of gizduino
void setup(){
     // initialize all the readings to 0:
    for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
void loop(){
    // subtract the last reading:
  total= total - readings[index];
  // read from the sensor:
  readings[index] = analogRead(inputPin);
  // add the reading to the total:
  total= total + readings[index];
  // advance to the next position in the array:
  index = index + 1;
  // if we're at the end of the array...
  if (index >= numReadings)
    // ...wrap around to the beginning:
    index = 0;
  // calculate the average:
  average = total / numReadings;
//  int val = analogRead(senseMic);
  Serial.println(average);
  //If Wind Is blown
  if (average > 540 || average < 490){
  tone(inputPin, 277.180);
  else{
    noTone(inputPin);
  //delay(1000);
Thank you sir, I updated my code and combined it with the smoothing code. I will try to test it tomorrow. BTW, am I doing the code right? lol
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
So you have AC coupling and the resistors setting the level to  an analog read of ~511 with no wind blown, and then the output would turn on/off from there.
I think perhaps using an envelope follower might give a better result, so the level into the ADC would be a steadier DC-ish kind of level.
Take the amplified signal you have now (IC1), rectify it (IC2), and run it thru a low pass filter/buffer (IC3) to feed the ADC.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Cebu City
Offline Offline
Newbie
View Profile
IC1-IC4 is still LM358 right?
Logged
Montreal
Offline Offline
Edison Member
View Profile
WWW
Look here, they allow preview of books:
http://www.scribd.com/doc/52955966/Arduino-Cookbook
 What do you should search, if this link 'd fail in your country, is:
O'Reilly  Arduino Cook Book by Michael Margolis 2-nd edition
pages 198 - p. 202 Detecting Sound
There is a code, all explain in great details.
Logged
Cebu City
Offline Offline
Newbie
View Profile
okay magician thanks I will look into this and test it out right away tomorrow. smiley-grin
Logged
Pages: [1]   Go Up
Print
Jump to:
