Topic: Serial Library requiring a lot of memory? (Read 2989 times) previous topic - next topic
retrolefty
Quote
and the USB connection as well gets allocated a serial port and pulls in more resources from the USB libraries).
On a mega board? I could see USB stuff possibly required for a Leonardo type board but why would a bog standard Uno or Mega board require anything to do with USB in a sketch compilation?
Lefty
Coding Badly
Quote
This project is for an home automation system I am working on.
In that case, you should be considering RS-422, RS-485, Ethernet, CANBUS, LINBUS, etcetera instead of TTL-serial.
tobyb121
Quote
Lefty
Yes sorry, my mistake, there's only 512 bytes allocated to buffers, still it makes up the majority of the RAM that is allocated by the serial library.
Nick Gammon
If you want, you can edit HardwareSerial.cpp and HardwareSerial.h and either change the buffer size (very easy), or turn off some of the serial ports (a bit harder but still relatively easy).
Quite right. Those calculations show where the memory is going. You can just "comment out" the declarations for Serial1, Serial2, Serial3 to save the memory their buffers use.
It's a pity the Serial library doesn't do a "new" to allocate the memory (eg. in Serial.begin) but that's life.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
