Pages: [1] 2   Go Down
Author Topic: Text Array  (Read 552 times)
Colorado
Reviving dead brain cells with Arduinos.
Is there a way to do something like this:
char sNames[7] = {'Sun', 'Mon', 'Tue', 'Wed', 'Thu', 'Fri', 'Sun'};
Serial.print(sNames[1]);
And have it output 'Mon' ?
Seems silly to have to write a switch case to figure out what to print.
Des Moines, WA - USA
char* sNames[] = {
      "Sun" // 0
    , "Mon" // 1
    , "Tue" // 2
    , "Wed" // 3
    , "Thu" // 4
    , "Fri" // 5
    , "Sat" // 6
« Last Edit: January 08, 2013, 12:41:45 am by lloyddean » Logged
Colorado
Danke!
UK
NB - double quotes and a pointer.
France
Scientia potentia est.
Or,
char sNames[7][4] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sun"};
Seattle, WA USA
Online Online
Seattle, WA USA
On some calendars, Sat comes after Fri.
UK
Or,
What does that actually do? And specifically, what does it do if the number of characters in an initialiser string is not 3?
Or,
That would create a matrix like this
1
2
3
0'S''u''n''\0'
1'M''o''n''\0'
2'T''u''e''\0'
3'W''e''d''\0'
4'T''h''u''\0'
5'F''r''i''\0'
6'S''a''t''\0'
« Last Edit: January 08, 2013, 10:11:03 am by llukkari » Logged
UK
And the second question?
UK
Strings should be null terminated, hence 4 instead of 3.
UK
Not sure whether you intended that to answer the question I asked, but it doesn't.
Simply allocate space that is not used. If it would have been declared as array[5] = "abc" it would contain:
0 1 2 3  4
a b c \0 X
where X is whatever junk was there to begin with. However, no you can also use strcpy(array, "abcd") and not worry about it.
UK
That's if the initialiser is smaller than the declared size. What about the other case?
Absolutely anything can happen, horrible nondeterministic things eg. nasal demon will fly out.
« Last Edit: January 08, 2013, 04:01:32 pm by llukkari » Logged
Seattle, WA USA
Online Online
Seattle, WA USA
There will be an error message from the compiler.
Pages: [1] 2   Go Up
