Topic: NRF24L01 And Ethernet Shield NOT Working Together On Mega 2560 (Read 1 time) previous topic - next topic
Hi everyone,
I am getting a error when i try and use the NRF24L01 with a ethernet shield
When I use the following code it knocks out the RF, How would i get them both to work with each other? i need to get the data from the web and then send it via RF. When i remove the following Ethernet.begin(mac) the RF starts sending out the data.
#include <SPI.h>
#include <Ethernet.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
int data;
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "www.*********.com";
EthernetClient client;
void setup(){
    Mirf.spi = &MirfHardwareSpi;
   Mirf.cePin = 48;
  Mirf.csnPin = 49;
  Mirf.setRADDR((byte *)"clie1");
  Mirf.payload = sizeof(data);
  Mirf.channel = 67;
void loop(){
        if (Ethernet.begin(mac) == 0) {
  //byte data[Mirf.payload];
  data = 8888;
  Mirf.setTADDR((byte *)"serv1");
  Serial.println("Finished sending");
Thank you for taking the time to read and if you have replied thank you
I suppose your Ethernet shield could be conflicting with some of the pins used to connect to the nRF24L01. I suggest you look at the documentation for it and work out which pins it uses.
