Author Topic: Ethernet Shield/Ethernet Microcontroller Question  (Read 164 times)
Im new to the arduino and am currently working on a school project, i was wondering what the difference would be between the following two:
-The Arduino Ethernet Microcontroller With PoE (http://tinyurl.com/a67mxoe)
-And the Arduino Uno USB Microcontroller Rev 3 with Arduino Ethernet Shield ( http://tinyurl.com/alhpypg , http://tinyurl.com/bz7tyuj )
I need the arduino to do some polling and send the data out via ethernet, is this possible with the ethernet microcontroller? (Im wondering this because getting the ethernet microcontroller would help save on physical space).
« Last Edit: January 08, 2013, 08:17:32 am by NickPatey » Logged
Anyone?
Miramar Beach, Florida
Online Online
I have not used the Arduino Ethernet. It does not have a usb port built in, so take that into consideration. If you want that function, you will need a usb card.
The advantage of the ethernet shield is the ability to move it from device to device. If you find the Uno does not have the memory or digital pin capability you require, you can purchase a Mega2560 (like I did), and move the shield to it.
Dee Why NSW
Either will do. I have a Uno with built-in Ethernet and a mega with separate shield. I believe both can use POE, I have never felt the need to use it with either.
(edit)
I'm amazed at what Tim wrote, and the price. If you want to go that way, I suspect you would be better off with an Etherten like mine.  It has USB, Ethernet and SD card all-in-one and seems competitively priced. I guess an Arduino with no USB has a place in this world, but surely not for a school project.
« Last Edit: January 08, 2013, 09:55:47 am by Nick_Pyner » Logged
The Etherten looks pretty ideal for me actually, im just wondering about the coding, does the Etherten use the same code that the Arduinos use? If it doesnt i would stick with the Arduino because of the large library of existing programs and codes available.
So im assuming it can be be programmed through USB to poll data and send this data out via ethernet? I want to be 100% sure before ordering, because im on a limited schedule and want to avoid having to avoid another product if it doesnt meet my needs.
Dee Why NSW
The EtherTen is just a tarted-up Uno and uses the standard Arduino IDE in exactly the same way - including all the libraries.. It requires its own driver for initial installation, as it is a unique third-party device.
You use the desktop to programme it via USB cable. The devices you are polling are usually connected separately by various means to the sockets provided.
The data is sent from the Ethernet and that is sent direct to the world. I use the cosm feed service for this, i.e. people go to cosm, not to me, and I guess it is the obvious approach for your project.
https://cosm.com/feeds/83153
Alright sounds good to me, and for my project if you were wondering, im using the arduino to poll a power mater and send the ethernet signal through the house to a computer using a powerline adapter.
Dee Why NSW
Ah... I misunderstood you. What you are proposing is a hell of a lot simpler and I'm sure you will be fine. You might find this interesting          http://www.parallax.com/tabid/393/default.aspx
It is not for Arduino but can be painlessly adapted, and is just the thing for you get the leading edge, and piss over all your colleagues........
« Last Edit: January 08, 2013, 05:48:38 pm by Nick_Pyner » Logged
OMG THANK YOU, thats EXACTLY something i was looking for, if it ends up that i use that in conjunction with a self-made visual basic program then its makes my project a LOT easier.
