Loading...
Pages: [1]   Go Down
Author Topic: Arduino Mega e SPI  (Read 212 times)
Offline Offline
Newbie
View Profile
Hello everyone
I should interfacing my Arduino Mega2560 mcp4921 with a DAC that uses the SPI.
I found on web a code arduino and I have made ​​some changes to the case, but I simulated all with Proteus and does not really work the DAC.
I checked power of both devices but nothing to do
Can anyone help me?
Thanks in advance
I enclose the following code written
Code:
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#define INTERNAL1V1 2
#define INTERNAL2V56 3
#else
#define INTERNAL 3
#endif
// SPI Interface SS_PIN(PB2), SCK_PIN(PB5), MOSI_PIN(PB3), MISO_PIN
// Arduino Pin 10 13 11 12
// MCP4921 DAC SS SCK MOSI n/a
#include "SPI.h"
// ATmega328P ADC
int analogPin = 0; // analog input channel
// ADC analog input value
word sensorValue = 0; // equivalent to unsigned int
// Byte of data to output to DAC
byte data = 0;
int digitalPin=53;
  //set pin(s) to input and output
  //pinMode(53, OUTPUT);
  SPI.begin(); // wake up the SPI bus.
  SPI.setBitOrder(MSBFIRST);
  pinMode(analogPin, INPUT);
  pinMode(digitalPin,OUTPUT);
  analogReference(INTERNAL2V56); //For 1280 and 2560
  //Serial.begin(9600);
  //pinMode(2, INPUT);
// read the value from the sensor:
sensorValue = analogRead(analogPin); // comment out this line to test DAC
// sensorValue = 0x0200; // 0x03FF = Vref, 0x0200 = 1/2 Vref
sensorValue = sensorValue << 2 ; // 10 bit ADC to 12-bit DAC word
// set SS pin low, beginning 16-bit (2 byte) data transfer to DAC
digitalWrite(digitalPin, LOW);
// send high byte
data = highByte(sensorValue);
data = 0b00001111 & data; // clear 4-bit command field (optional)
data = 0b00110000 | data; // 0=DACA, 0=buffered, 1=1x, 1=output enabledSpi.transfer(data); // alt: shiftOut(MOSI, SCK, MSBFIRST, data);
// send low byte
data = lowByte(sensorValue);
SPI.transfer(data); // alt: shiftOut(MOSI, SCK, MSBFIRST, data);
// set SS pin high, completing 16-bit transfer to DAC
digitalWrite(digitalPin, HIGH);
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Was there a question?
What do your debug prints tell you is happening?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
I must receive digital string from pc by serial port and shift it to a dac (via spi)
In proteus this skecth doesn't work, can you help me to doing this project?
thanks in advance!
Logged
Pages: [1]   Go Up
Print
Jump to:
