Topic: malfunctioning.... (Read 4558 times) previous topic - next topic
naeemuzz
i created a program to just check the pin 8 gets a i/p so that the pin 9 will give some output...unfortunately even without the i/p its showing o/p...subsequently i found that wen we shake the uno its giving output!:(....so wat ds that show?
HazardsMind
Bad wire connection, or a bad cold solder somewhere.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
AWOL
I guess "floating input", but it really is just a guess, because I don't see code or a schematic.
Grumpy_Mike
It shows that it is not connected reliably, what else could it show?
Check your soldering. If you are using solder less bread board you now know why it is a bad idea.
PeterH
If that behaviour isn't what you wanted, then it shows that you've got a problem.
Perhaps if somebody more experienced with Arduino reviewed your software and hardware design then they might be able to guess what was causing it.
naeemuzz
so u mean the problem is wth ma circuit or program...thats affordable...my qstn will ther be chance that ma arduino is damaged??
Delta_G
This may come as quite a shock to you, but nobody here can see your code or your circuit.  So nobody here can possibly know if you've got a broken board or if you have made a mistake.  I'm betting you have a floating pin.  Common mistake for people to make.  But unless you want to show us the schematic and the code no one here will ever be able to tell you.
If at first you don't succeed, up - home - sudo - enter.
naeemuzz
#7
Jan 18, 2013, 05:44 pm Last Edit: Jan 18, 2013, 06:09 pm by AWOL Reason: 1
int yel= 1;
int blue= 0;
int in=9;
 pinMode(yel, OUTPUT);
 pinMode(blue, OUTPUT);
 pinMode(in, INPUT);
 if(digitalRead(in)==HIGH)
   for(int i=1;i<=5;i++)
     digitalWrite(yel, HIGH);
     delay(1);
     digitalWrite(yel, LOW);
     delay(1);
     delay(1);
     delay(1);
     digitalWrite(blue, HIGH);
     delay(1);
     digitalWrite(blue,LOW);
     delay(1);
     delay(1);
     digitalWrite(blue, LOW);
     delay(1);
welll this my code...circuit is just ardui itself...snc pin 1 nd 0 are connectd to onbord leds i just tested testd it wth that...
Moderator edit: excess whitespace removed and CODE TAGS added.  Grrr.
retrolefty
Those delay(1) statements are not going to be able to be seen by human eye site as the eye can't detect a one millisecond blink of an led. Also you need to show the wiring of your digital input pin as that is what may or may not have a floating input pin condition.
Lefty
PeterH
So nothing connected on pin 9? That means you have a floating input.
By the way, if you could take the trouble to write proper English rather than txtspk it would be appreciated.
Grumpy_Mike
Is that what it is, I thought he was either very hip or retarded, possibly both.  :P
Anyway as other have said "schematics R us" need your schematic for anything meaningful to be written.
naeemuzz
well...there wasn't any circuit...i didnt connect anythng to the i/p pin...even befor connecting the pin the uno started showing the blinking leds..so frustrated and didnt attemptd to connect anything...
one more dout what is maximum baud rate that can be supported by arduino uno?
Grumpy_Mike
naeemuzz
Khalid
First of all " Dont break Legs of English"... Write it as it should be dont chew it..
secondly, post your programm...
The more you shake Arduino the more it will give you milk...
Simply...You can't afford me..
Author Of:
http://my-woodcarving.blogspot.com/
http://www.free3dscans.blogspot.com/
http://my-diysolarwind.blogspot.com/
Oops..some one gave me Karma...:)
