Loading...
Pages: [1] 2   Go Down
Author Topic: Preventing PCB interference  (Read 535 times)
UK
Offline Offline
Sr. Member
View Profile
So, I'm working on a project at the moment - and the PCB I'm building for it is only two sided, as I intend to produce the PCB myself.
I'm using all surface mount parts, with all the signal and control lines etc on one side of the PCB - and am intending on putting all of the power circuitry on the other side of the PCB, i.e. regulator, polyfuses, tranzorbs, h-bridge, MOSFETs etc.
I'm worried about interference between devices that are driving noisy / inductive loads such as the H - Bridge as clearly there is no power plane in the middle of my PCB. I have ~ 5 MOSFETs and ~ 5 IGBTs driving inductive loads too with spikes clamped around ~400V.
Am I likely to experience problems with this? I'm reading app notes etc from multiple sources, most of which suggest of course filling as much of the board, both sides, as possible with ground copper.
What other precautions should I put in place? Or, should I 'breakout' the devices driving the inductive loads onto another PCB that is stacked on top with a full ground plane?
Many thanks in advance.
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
For starters, read this thread and pay special attention to the idea about "star grounding",
http://arduino.cc/forum/index.php/topic,141348.0.html
« Last Edit: January 08, 2013, 12:47:09 pm by oric_dan(333) » Logged
Murphy's Corollary: the "real" problem is usually what they don't tell you about, which leads to endless second-guessing. m
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Yes.
Quote
No putting a ground plane everywhere will just help the interference get into the ground plane.
Keep the ground plane away from interference, do not put it under devices likely to cause it.
Logged
UK
Offline Offline
Sr. Member
View Profile
Quote
Ah, I see - what are large ground planes and gridded ground planes for like used on the old Diecimila board? My inductors are not the board, but rather are external components such as motors and solenoids etc, if that makes a difference? But of course, some traces will be at high voltage during the spike.
Star grounding would look somewhat impressive with so many grounds :-)
Logged
Online Online
Brattain Member
View Profile
WWW
Quote
Try and apply the star technique to grounds that carry the most current.
Logged
Offline Offline
Edison Member
View Profile
WWW
As G_M says, the star grounding arrangement is to get the lines carrying the noisy
currents isolated from the lines powering the sensitive electronics.
Logged
Offline Offline
Full Member
View Profile
I would also keep h-bridge, MOSFET to one side of the board and not run any signal tracks under them.
I have seen that it works better to keep power and motor control switching more to there self. And run signal line to them far less noise pick up. And as said don't loop the gnd or the VDD line.
Logged
UK
Offline Offline
Sr. Member
View Profile
So there is no issue with using a bus bar type trace layout on my control side of the board, but on the power side - use the star method for grounding the high current components?
On the subject then of power, what about 5v and 12v power lines? Should I make these 'planes', or route these individually to their respective devices?
Quote
I.e leave those devices over in a corner by themselves, with little around them? When you say don't loop, as in - don't create ground loops, but use star grounding?
« Last Edit: January 08, 2013, 01:57:01 pm by jtw11 » Logged
Offline Offline
Edison Member
View Profile
WWW
1. just lay out the pcb with the normal microcontroller cktry on one side and the h-bridge
    cktry on the other side, and only connect them together at a single ground point. Some
    people will use an inductor [choke] or ferrite to make the connection.
2. once this is in place, simply run the h-bridge control signals from the microcontroller
   across to the h-bridge. Always good to put series-Rs in these lines to help protect the
   uC from motor noise feeding back from the h-bridge.
3. locate the main terminals for motor power on the h-bridge side of the board, so the
    motor currents never cross to the other side, and never flow through the single point
    ground connection of item #1. Add bypass [0.1 uF] and reservoir [100 uf or more]
    caps right at the same terminals.
4. it's best to use 2 separate external power supplies, one for the logic part and another for
    the motors. If you can't do this, then the next best thing to do is connect a single supply
    to the motor side, and jumper "1" wire over externally to supply logic power. This way,
    the motor currents are always confined to the h-bridge side, and not flowing between
    the 2 sides. Don't make an external ground connection between the 2 sides, as then you
    will have a ground loop.
5. if you have analog cktry on the pcb, confine it to a separate area from the digital logic
    cktry, and also on the opposite side of the pcb from the h-bridge cktry.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Can you you arrange it so that insted of all components being one layer of the board and allk the rest the other layer, have one group be one end of the board and the other group be the other end?
Then any traces & vias needed to make the routing work can be with the similar signal levels, and the high voltage/high current traces & vias can be seperated away, not overlapping the more sensitive lower voltage/current parts.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
UK
Offline Offline
Sr. Member
View Profile
Quote
Will do, but using star traces to that single ground point on the power side. Your mention of a ferrite, do you mean the small ferrite beads such as the following SMD bead type? http://tinyurl.com/aygg7hg
...and when you say make the connection, I assume I only need one? So I connect the control side of the PCB to that ground via, with a small SMD ferrite bead
Quote
Okay - I haven't tested with series resistance yet, I'll whack some 1k resistors onto the control lines tomorrow and check my waveforms. No problem with feeding these as visa through the board, won't long traces have quite some inductance?
Quote
    ground connection of item #1. Add bypass [0.1 uF] and reservoir [100 uf or more] caps right at the same terminals.
My h-bridge is a dedicated IC, an LMD18200T - I have the 12V supply for this IC decoupled with .1uF and a 220uF reservoir as per application note, and the outputs have bootstrap caps back into the IC, so do I need these caps on the output? Or do you mean two caps across the two motor terminals? I was planning to do this already to help reduce noise.
Quote
    the 2 sides. Don't make an external ground connection between the 2 sides, as then you will have a ground loop.
I've only got one external power supply, but have a 60 way connector on to my PCB and have a couple of spare pins - perhaps providing 12v to two pins from the same source, so each side of the PCB has its own 12V pin would serve a similar purpose?
When you say external ground connection, as in - the ONLY ground between each side should be the one ground via discussed under heading 1?
Quote
My only analog signals are analog voltages going in to the ADC of the MCU, so I can't really avoid running these from the pcb connector over to the MCU....
Thanks for your help so far, by the way :-)
Quote
]Can you you arrange it so that insted of all components being one layer of the board and allk the rest the other layer, have one group be one end of the board and the other group be the other end?
I'm afraid not, space constraints dictate otherwise - both sides of an 74 x 100 pcb are packed tight with components, it's going to be a challenge to keep components on the signal side not underneath high voltage / noisy components on the other side.
« Last Edit: January 08, 2013, 04:01:25 pm by jtw11 » Logged
Offline Offline
Edison Member
View Profile
WWW
Yeah, I meant to mention earlier and forgot, as Bob says, there is no rule that says it's
necessary to keep the power/ground and signal traces on opposite sides of the board.
Your other comments sound ok, except that, the bootstrap caps are small-value caps that
are necessary for the charge-pump cktry inside the LM18200 to work properly. You still want
the 2 caps across the h-bridge power terminals as the d/s recommends, although the values
given seem high to me. But maybe that h-bridge is finicky that way.
Caps across the motor terminals may help, but you should still use all the others too. For
reference, you might also check out these links, especially the one about the Main Capacitor,
http://www.4qdtec.com/pwm-01.html
http://www.4qd.co.uk/serv/appnotes/machinewire.html
http://www.lh-electric.net/tutorials/gnd_loop.html
Logged
UK
Offline Offline
Sr. Member
View Profile
Quote
Ah, that gives me a thought.... One end of the PCB could be the power end, both sides - whilst the other end would be control, both sides. That way, traces and vias shall not intertwine HV/noisy signals etc, and all power grounds can star to a central common ground connection at a central edge right next to the connector for the PCB.
Are my 220 and 1uF caps across the bridges power pins not the 'main' caps however? The diagram on th page you linked certainly imply that?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
"One end of the PCB could be the power end, both sides - whilst the other end would be control, both sides. "
That's what I was saying in #9.
Logged
Offline Offline
Edison Member
View Profile
WWW
Quote
Yeah, same thing. The LM18200 d/s shows them at the h-bridge, the link page basically has them at the power
entry terminals, but these points should be right next to each other on the pcb.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
