Loading...
Pages: [1] 2   Go Down
Author Topic: Disabling UART on Due?  (Read 1236 times)
Nowhere at all
Offline Offline
Newbie
Patience, discipline
View Profile
On the 8bit AVR you would use the "UCSR2B &= ~(_BV(RXEN2))"  command to disable a serial port on it (USART2 in this case).
Does anyone know how to do the same thing with Due?
BR
Logged
Offline Offline
Newbie
View Profile
what do you mean by disabling a serial port?
I'm not expert in AVR but I know that all peripherals are clocked by default, so consuming power even if not used.
I know a bit more the SAM3X and in its case the peripherals are not clocked by default.
This means that all pins are dedicated to General Purpose I/O Controller and not to a multiplexed peripheral (like USART).
Thus, the pins need to declared as being used by a peripheral to be used and the peripheral to be clocked before any use.
Am I guessing right what is behind your question?
Logged
Nowhere at all
Offline Offline
Newbie
View Profile
Thanks for your reply aethaniel
What i mean is, that i want to send some data over serial, then disable serial on the pins that it uses for it (lets say 0 and 1 of the Due board for USART0), and enable those pins as digital pins to do some stuff, and after the digital stuff is done, then turn back on the serial.
BR
Logged
Offline Offline
Edison Member
You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
View Profile
Sorry for the silly question, but what's connected to those pins ? Doesn't the DUE have enough GPIO pins to avoid going down that (seems to me) overly complicated path ?
Logged
Nowhere at all
Offline Offline
Newbie
View Profile
Trying to do some ISO-9141 (car ECU) communications, and i need to send a 5-baud start sequence which is done with:
Code:
pinMode(TX0, OUTPUT);
pinMode(RX0, INPUT);
digitalWrite(TX0, HIGH);
Serial.begin(10400);
BR
Logged
Offline Offline
Edison Member
View Profile
Thanks for your response. Looked up that code, very interesting smiley
Logged
Nowhere at all
Offline Offline
Newbie
View Profile
The "code" was so what i meant could be understood, not a sketch!
Here is the full code for the function:
Code:
void iso_init()
  long currentTime = millis();
  static long initTime;
  switch (ISO_InitStep)
    case 0:
      // setup
      ECUconnection = false;
      serial_tx_off(); //disable UART so we can "bit-Bang" the slow init.
      serial_rx_off();
      initTime = currentTime + 3000;
      ISO_InitStep++;
    case 1:
      if (currentTime >= initTime)
        // drive K line high for 300ms
        digitalWrite(K_OUT, HIGH);
        initTime = currentTime + 300;
        ISO_InitStep++;
    case 2:
    case 7:
        // start or stop bit
        digitalWrite(K_OUT, (ISO_InitStep == 2 ? LOW : HIGH));
        initTime = currentTime + (ISO_InitStep == 2 ? 200 : 260);
        ISO_InitStep++;
    case 3:
    case 5:
        // two bits HIGH
        initTime = currentTime + 400;
        ISO_InitStep++;
    case 4:
    case 6:
        // two bits LOW
        digitalWrite(K_OUT, LOW);
        ISO_InitStep++;
    case 8:
        // bit banging done, now verify connection at 10400 baud
        byte b = 0;
        // switch now to 10400 bauds
        // wait for 0x55 from the ECU (up to 300ms)
        //since our time out for reading is 125ms, we will try it up to three times
        byte i=0;
        while(i<3 && !iso_read_byte(&b))
          i++;
        if(b == 0x55)
          ISO_InitStep++;
          // oops unexpected data, try again
          ISO_InitStep = 0;
    case 9:
        byte b;
        bool bread;
        bread = iso_read_byte(&b);  // read kw1
        bread = iso_read_byte(&b);  // read kw2
        // 25ms delay needed before reply (url with spec is on forum page 56)
        // it does not work without it on VW MK4
        delay(25);
        // send ~kw2 (invert of last keyword)
        iso_write_byte(~b);
        // ECU answer by 0xCC (~0x33)
        // read several times, ECU not always responds in time
        byte i=0;
        while (i<3 && !bread)
          i++;
        if (b == 0xCC)
           ECUconnection = true;
        ISO_InitStep = 0;
void serial_rx_off()
  UCSR0B &= ~(_BV(RXEN0));  //disable UART RX
void serial_tx_off()
   UCSR0B &= ~(_BV(TXEN0));  //disable UART TX
   delay(20);                 //allow time for buffers to flush
I need to replicate the last two functions ( serial_tx_off() and serial_rx_off() ) on Due in order for this to work.
BR
« Last Edit: January 09, 2013, 06:14:25 pm by Bi0H4z4rD » Logged
Offline Offline
Edison Member
View Profile
Ouch, I meant that *iso* code smiley-razz
Going to have a look at your code, though smiley-grin
Logged
Nowhere at all
Offline Offline
Newbie
View Profile
Ouch, my missunderstanding too i guess  smiley-razz
Anyway code is not mine, im just modding it to do some other stuff, but that's the part i need to get working.
If you want to see the full project for the code i have posted, you can find it here:
http://code.google.com/p/opengauge/wiki/OBDuino
BR
Logged
Offline Offline
Edison Member
View Profile
Section 29.2.2 of the SAM3X datasheet and block diagram in section 29.2.3 suggest peripheral clocks can be independently disconnected. So I guess one way to "turn off" an USART would be to disable its clock.
Disclaimer: just thinking out loud, I've just skimmed the datasheet smiley
Logged
Offline Offline
Edison Member
View Profile
BR
Hey, that's a nice project! Think I've googled you up a couple years ago smiley-razz
Getting some data off that OBD connector hidden somewhere under my steering wheel is one of the things I'd like to do sooner or later... Just bookmarked your project smiley
Logged
Nowhere at all
Offline Offline
Newbie
View Profile
Thanx for the reply! That code/project is not mine, i am using parts of its code to do some other stuff, like reading ecu sw info and other service operations.
Anyway, i found some bugs in that code which are now corrected (and tested) and enable fast init, aswell as the bitbang for a more standard 9600bps communication speed instead of 10400bps.
Just for the record:
Uploaded with ImageShack.us
BR
Logged
Online Online
Sr. Member
View Profile
The SAM3X has registers PIO_PER and PIO_PDR which control whether a pin is used as a digital output or by a peripheral:
g_APinDescription[pin].pPort -> PIO_PER = g_APinDescription[pin].ulPin;  (pin is digital io)
g_APinDescription[pin].pPort -> PIO_PDR = g_APinDescription[pin].ulPin;  (pin is peripheral)
Posting this in the hope that it just works - if it does, great, if not then you're probably going to need to study the datasheet.
Logged
Nowhere at all
Offline Offline
Newbie
View Profile
Thanks stimmer, will definitely try this out and post results as soon as i do it.
BR
Logged
Offline Offline
Newbie
View Profile
hi Bi0H4z4rD,
sorry for late reply on this but yes, you should use what stimmer suggested you. This is the only way to assign a pin either to GPIO multiplexing or to a peripheral.
by the way, if you want to send 5bit frames, maybe are you able use the USART with the proper configuration. That way you won't have to do it manually:
36.2 Embedded Characteristics
• Programmable Baud Rate Generator
• 5- to 9-bit Full-duplex Synchronous or Asynchronous Serial Communications
I didn't check deeply the DS, so maybe am I wrong.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
