Topic: Disabling UART on Due? (Read 11344 times) previous topic - next topic
Bi0H4z4rD
thanks for your reply aethaniel
what i want to send is 8N1 bits at 5bps (baudrate), not 5 bits  :)
I'm still up to testing it, which should happen sometime before sunday.
BR
aethaniel
oooops i read a bit fast your posts, sorry.
Bi0H4z4rD
I have found what i was looking for:
Code: [Select]
USART2->US_CR = US_CR_TXEN;//Enables USART2 TX
USART2->US_CR = US_CR_RXEN;//Enables USART2 RX
USART2->US_CR = US_CR_TXDIS;//Disables USART2 TX
USART2->US_CR = US_CR_RXDIS;//Disables USART2 RX
But now i find that if i have set the pins as digital previously like this:
Code: [Select]
pinMode(16, OUTPUT);
pinMode(17, INPUT);
the USART2 wont start, and will stay in LOW status, and therefor, not read anything.
Any clues on how to solve that?
I already tried the
Code: [Select]
g_APinDescription[pin].pPort -> PIO_PER = g_APinDescription[pin].ulPin;  (pin is digital io)
g_APinDescription[pin].pPort -> PIO_PDR = g_APinDescription[pin].ulPin;  (pin is peripheral)
and it didnt do the job.
BR
Bi0H4z4rD
Now, this is weird...
This code:
Code: [Select]
#define IN    17 //RX2
#define OUT   16 //TX2
void setup(){
Serial2.begin(115200);
Serial2.print("123456");
pinMode(OUT, OUTPUT);
pinMode(IN, INPUT);
  digitalWrite(OUT, HIGH);
  delay(200);
  digitalWrite(OUT, LOW);
  delay(200);
  delay(200);
  delay(1400);
  delay(20);
  Serial.print("Done");
void loop(){}
Gives the following  response:
Uploaded with ImageShack.us
The red square represents the first (one time) "Serial2.print("123456");".
Any clues of what might be happening here?
BR
stimmer
Serial2 is USART1, not USART2.
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
Bi0H4z4rD
#20
Jan 12, 2013, 08:48 pm Last Edit: Jan 12, 2013, 09:19 pm by Bi0H4z4rD Reason: 1
Thanks for the tip stimmer!
I changed it from USART2 to USART1, but still getting exactly the very same thing on the LA.
The weird thing is that it does the "LOW/HIGH" thing before serial printing "123456" for the first time, while that is supposed to go after printing it.
BR
Markus_L811
Trying to do some ISO-9141 (car ECU) communications, and i need to send a 5-baud start sequence which is done with:
Code: [Select]
pinMode(TX0, OUTPUT);
pinMode(RX0, INPUT);
digitalWrite(TX0, HIGH);
Serial.begin(10400);
BR
You mean K-Line I think so you have the same Problem I have with L-Line and the USART may you can use an K-Line Transciever and the Lin support from the SAM.
Bi0H4z4rD
Thanks for your reply Markus.
You mean one like this one?: http://www.nxp.com/documents/application_note/AN00093.pdf
BR
stimmer
I can't understand exactly what didn't work with the PIO_PER/PDR approach - I modified your example like this:
Code: [Select]
#define IN    17 //RX2
void setup(){
  pinMode(0,INPUT);
  pinMode(1,INPUT);
g_APinDescription[IN].pPort -> PIO_PER = g_APinDescription[IN].ulPin;
g_APinDescription[OUT].pPort -> PIO_PER = g_APinDescription[OUT].ulPin;
pinMode(IN, INPUT);
  delay(200);
  delay(200);
  delay(200);
  delay(1400);
g_APinDescription[IN].pPort -> PIO_PDR = g_APinDescription[IN].ulPin;
g_APinDescription[OUT].pPort -> PIO_PDR = g_APinDescription[OUT].ulPin;
  delay(20);
void loop(){}
and connected pin 16 directly to pin 1 (to get output from Serial2 on the serial monitor), and also connected it to an LED. It appears to flash and transmit serial exactly as you'd want.
Bi0H4z4rD
You are totally right stimmer, just checked it with the LA and it works perfectly. I must have done something wrong while trying it.
Big thanks for the help!
BR
cyclegadget
I am working with K-line that is similar to yours. My code starts the bit-bang before activating the UART1.
I am using UART0 for debug. This is on a 1284 chip.
Code: [Select]
 digitalWrite (TX, HIGH); // makes K-line high 3
 digitalWrite(ledPin,HIGH);
 delay(2000);       // wait for K-line to be clear 3
 digitalWrite (TX, LOW); // makes K-line low  3
 delay(25);
 delay(25);        //last delay before first message
 Serial1.begin(10400);
Also, I think there is a function called Serial.end() to stop serial comms.. I am not positive about it though.
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
Markus_L811
Code: [Select]
 delay(25);
Hi I used this code on the Leonardo for Lin,
Code: [Select]
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
long interval = 250;
//Lin Initailisation
#define linspeed                19200
unsigned long Tbit = 1000000/linspeed;
#define uartlenght                 10
//Tbits Header
#define breakfield                 13
#define breakdelimiter              1
#define breakfieldinterbytespace    2
int frameerrordelay = ((breakfield + breakdelimiter) - uartlenght)*Tbit;
//int frameerrordelay = (breakfield + breakdelimiter + breakfieldinterbytespace) - uartlenght;
#define syncfield                  uartlenght
#define PIDfield                   uartlenght
#define syncfieldPIDinterbytedelay  0
int syncfieldPIDinterbytespace = syncfieldPIDinterbytedelay*Tbit;
//Tbit Response
#define responsedelay               8
int responsespace = responsedelay*Tbit;
#define interbytedelay              0
int interbytespace = interbytedelay*Tbit;
#define numbers  4
byte message[numbers],sending[numbers];
byte linb,sync,PID,checksum;
int n = 0;
  // initialize serial port and LIN:
  Serial.begin(19200);
  Lininit();
  pinMode(13, OUTPUT);
  blinking();
  LinReading();
//  LinWriting();
void LinReading() {
  LinRead();
  PrintlnLin();
  ClearFrame();
void LinWriting() {
  LinWrite(sending);
  Answer();
void Lininit() {
  Serial1.begin(linspeed);
  pinMode(0,INPUT_PULLUP);
void Answer() {
  for (int i=0;i<numbers;i++) {
     sending[i] = n;
  n++;
  n = n % 256;
  Serial.println(n,HEX);
void LinRead() {
  if (1<<FE1) {
    delayMicroseconds(frameerrordelay);               //after Frame Error Tbit to Sync Field
    if (Serial1.available() > 0) {
      sync = Serial1.read();
      if (sync != 0x55) {
        sync = 0x00;
      delayMicroseconds(syncfieldPIDinterbytespace);  //Interbyte Space
        PID = Serial1.read();
      delayMicroseconds(responsespace);               //after PID Tbit space
        message[i] = Serial1.read();
        if (interbytespace == 0) {                    //Interbyte Space
          delayMicroseconds(1);
          delayMicroseconds(interbytespace);
      checksum = Serial1.read();
    Serial.println("NO Break");
void LinResponse(byte* sending) {
  if (1<<FE1) {
      if (sync == 0x55) {
          if (PID == 0x11) {
              Serial1.write(sending[i]);
              Serial1.write(MessageCRC(message,0));
void LinWrite(byte* sending) {
  Serial1.end();
  pinMode(0,OUTPUT);
  digitalWrite(1, LOW);
  delayMicroseconds(breakfield*Tbit);                 //after Frame Error Tbit to Sync Field
  digitalWrite(1, HIGH);
  delayMicroseconds(breakdelimiter*Tbit);
  Serial1.write(0x55);
  Serial1.write(0x03);
  Serial1.write(MessageCRC(sending,0));
void PrintlnLin() {
  if(sync != 0) {
//    Serial.print("Break Field   Sync:  ");
//    Serial.print(sync,HEX);
    Serial.print("PID:  ");
    Serial.print(PID & 0x3F,HEX);            //PID without CRC
    Serial.print("   CRC:  ");
    Serial.print(PIDCRC(PID));
    Serial.print("  Message:  ");
      Serial.print(message[i],HEX);
      Serial.print(";");
    Serial.print("  Checksum:  ");
    Serial.print(checksum,HEX);
    Serial.print("  ChecksumCRC:  ");
    Serial.println(MessageCRC(message,0),HEX);
void ClearFrame() {
  sync = 0;
  PID = 0;
    message[i] = 0;
  checksum = 0;
void blinking() {
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(13, ledState);
int PIDCRC(int PID) {
  int P0 = ((PID>>0) + (PID>>1) + (PID>>2) + (PID>>4)) & 1;
  int P1 = ~((PID>>1) + (PID>>3) + (PID>>4) + (PID>>5)) & 1;
  return (P0 | (P1<<1));
byte MessageCRC(byte* message, uint16_t sum) {
    sum += message[i];
  while(sum>>8)  // In case adding the carry causes another carry
    sum = (sum&255)+(sum>>8);
  return (~sum);
And for the Due I have Isolated and changed the Atmel Framework Examplecode. I will attach it but I have at the moment not the time for tests also I had also to comment out the USART1_Handler in the variant.cpp to let it complie proper.
B.R.
Markus
