Nowhere at all
Patience, discipline
« Reply #15 on: January 10, 2013, 12:48:59 pm » |
thanks for your reply aethaniel what i want to send is 8N1 bits at 5bps (baudrate), not 5 bits  I'm still up to testing it, which should happen sometime before sunday. BR
« Reply #16 on: January 12, 2013, 11:00:20 am » |
oooops i read a bit fast your posts, sorry.
Nowhere at all
« Reply #17 on: January 12, 2013, 12:21:50 pm » |
I have found what i was looking for: USART2->US_CR = US_CR_TXEN;//Enables USART2 TX USART2->US_CR = US_CR_RXEN;//Enables USART2 RX USART2->US_CR = US_CR_TXDIS;//Disables USART2 TX USART2->US_CR = US_CR_RXDIS;//Disables USART2 RX
But now i find that if i have set the pins as digital previously like this: pinMode(16, OUTPUT); pinMode(17, INPUT); the USART2 wont start, and will stay in LOW status, and therefor, not read anything. Any clues on how to solve that? I already tried the g_APinDescription[pin].pPort -> PIO_PER = g_APinDescription[pin].ulPin; (pin is digital io) g_APinDescription[pin].pPort -> PIO_PDR = g_APinDescription[pin].ulPin; (pin is peripheral) and it didnt do the job. BR
Nowhere at all
« Reply #18 on: January 12, 2013, 12:47:43 pm » |
Now, this is weird... This code: #define IN 17 //RX2 #define OUT 16 //TX2
void setup(){ Serial2.begin(115200); Serial.begin(115200); Serial2.print("123456"); delay(1000); USART2->US_CR = US_CR_RXDIS; USART2->US_CR = US_CR_TXDIS; pinMode(OUT, OUTPUT); pinMode(IN, INPUT); delay(1000); digitalWrite(OUT, HIGH); delay(200); digitalWrite(OUT, LOW); delay(200); digitalWrite(OUT, HIGH); delay(200); digitalWrite(OUT, LOW); delay(1400); USART2->US_CR = US_CR_TXEN; USART2->US_CR = US_CR_RXEN; Serial2.print("123456"); delay(20); Serial2.print("123456"); Serial.print("Done"); } void loop(){} Gives the following response:  Uploaded with ImageShack.usThe red square represents the first (one time) "Serial2.print("123456");". Any clues of what might be happening here? BR
Online
« Reply #19 on: January 12, 2013, 02:07:17 pm » |
Serial2 is USART1, not USART2.
Nowhere at all
« Reply #20 on: January 12, 2013, 02:48:22 pm » |
Thanks for the tip stimmer!
I changed it from USART2 to USART1, but still getting exactly the very same thing on the LA.
The weird thing is that it does the "LOW/HIGH" thing before serial printing "123456" for the first time, while that is supposed to go after printing it.
BR
« Last Edit: January 12, 2013, 03:19:40 pm by Bi0H4z4rD »
Germany
« Reply #21 on: January 12, 2013, 05:45:42 pm » |
Trying to do some ISO-9141 (car ECU) communications, and i need to send a 5-baud start sequence which is done with: pinMode(TX0, OUTPUT); pinMode(RX0, INPUT);
digitalWrite(TX0, HIGH); .... Serial.begin(10400); BR You mean K-Line I think so you have the same Problem I have with L-Line and the USART may you can use an K-Line Transciever and the Lin support from the SAM.
Online
« Reply #23 on: January 13, 2013, 06:25:12 pm » |
I can't understand exactly what didn't work with the PIO_PER/PDR approach - I modified your example like this: #define IN 17 //RX2 #define OUT 16 //TX2
void setup(){ pinMode(0,INPUT); pinMode(1,INPUT); Serial2.begin(115200); Serial2.print("123456"); delay(1000);
g_APinDescription[IN].pPort -> PIO_PER = g_APinDescription[IN].ulPin; g_APinDescription[OUT].pPort -> PIO_PER = g_APinDescription[OUT].ulPin;
g_APinDescription[IN].pPort -> PIO_PDR = g_APinDescription[IN].ulPin; g_APinDescription[OUT].pPort -> PIO_PDR = g_APinDescription[OUT].ulPin;
Serial2.print("123456"); delay(20); Serial2.print("123456"); }
void loop(){}
and connected pin 16 directly to pin 1 (to get output from Serial2 on the serial monitor), and also connected it to an LED. It appears to flash and transmit serial exactly as you'd want.
Nowhere at all
« Reply #24 on: January 13, 2013, 07:38:30 pm » |
You are totally right stimmer, just checked it with the LA and it works perfectly. I must have done something wrong while trying it.
Big thanks for the help!
BR
Greenville, IL
Online
Warning Novice on board! 0 to 1 chance of errors!
« Reply #25 on: January 14, 2013, 01:37:05 pm » |
I am working with K-line that is similar to yours. My code starts the bit-bang before activating the UART1. I am using UART0 for debug. This is on a 1284 chip. digitalWrite (TX, HIGH); // makes K-line high 3 digitalWrite(ledPin,HIGH); delay(2000); // wait for K-line to be clear 3 digitalWrite (TX, LOW); // makes K-line low 3 delay(25); digitalWrite (TX, HIGH); // makes K-line high 3 delay(25); //last delay before first message Serial1.begin(10400); Also, I think there is a function called Serial.end() to stop serial comms.. I am not positive about it though.
Germany
« Reply #26 on: January 16, 2013, 05:31:26 am » |
I am working with K-line that is similar to yours. My code starts the bit-bang before activating the UART1. I am using UART0 for debug. This is on a 1284 chip. digitalWrite (TX, HIGH); // makes K-line high 3 digitalWrite(ledPin,HIGH); delay(2000); // wait for K-line to be clear 3 digitalWrite (TX, LOW); // makes K-line low 3 delay(25); digitalWrite (TX, HIGH); // makes K-line high 3 delay(25); //last delay before first message Serial1.begin(10400); Also, I think there is a function called Serial.end() to stop serial comms.. I am not positive about it though. Hi I used this code on the Leonardo for Lin, int ledState = LOW; // ledState used to set the LED long previousMillis = 0; // will store last time LED was updated
long interval = 250;
//Lin Initailisation #define linspeed 19200 unsigned long Tbit = 1000000/linspeed;
#define uartlenght 10
//Tbits Header #define breakfield 13 #define breakdelimiter 1 #define breakfieldinterbytespace 2
int frameerrordelay = ((breakfield + breakdelimiter) - uartlenght)*Tbit; //int frameerrordelay = (breakfield + breakdelimiter + breakfieldinterbytespace) - uartlenght;
#define syncfield uartlenght #define PIDfield uartlenght #define syncfieldPIDinterbytedelay 0 int syncfieldPIDinterbytespace = syncfieldPIDinterbytedelay*Tbit;
//Tbit Response #define responsedelay 8 int responsespace = responsedelay*Tbit; #define interbytedelay 0 int interbytespace = interbytedelay*Tbit;
#define numbers 4 byte message[numbers],sending[numbers]; byte linb,sync,PID,checksum; int n = 0;
void setup() { // initialize serial port and LIN: Serial.begin(19200); Lininit(); pinMode(13, OUTPUT); }
void loop() { blinking(); LinReading(); // LinWriting(); }
void LinReading() { LinRead(); PrintlnLin(); ClearFrame(); }
void LinWriting() { LinWrite(sending); Answer(); delay(1000); }
void Lininit() { Serial1.begin(linspeed); pinMode(0,INPUT_PULLUP); }
void Answer() { for (int i=0;i<numbers;i++) { sending[i] = n; } n++; n = n % 256; Serial.println(n,HEX); }
void LinRead() { if (1<<FE1) { delayMicroseconds(frameerrordelay); //after Frame Error Tbit to Sync Field if (Serial1.available() > 0) { sync = Serial1.read(); if (sync != 0x55) { sync = 0x00; } delayMicroseconds(syncfieldPIDinterbytespace); //Interbyte Space if (Serial1.available() > 0) { PID = Serial1.read(); } delayMicroseconds(responsespace); //after PID Tbit space for (int i=0;i<numbers;i++) { message[i] = Serial1.read(); if (interbytespace == 0) { //Interbyte Space delayMicroseconds(1); } else { delayMicroseconds(interbytespace); } } checksum = Serial1.read(); } } else { Serial.println("NO Break"); } }
void LinResponse(byte* sending) { if (1<<FE1) { delayMicroseconds(frameerrordelay); //after Frame Error Tbit to Sync Field if (Serial1.available() > 0) { sync = Serial1.read(); if (sync == 0x55) { delayMicroseconds(syncfieldPIDinterbytespace); //Interbyte Space if (Serial1.available() > 0) { PID = Serial1.read(); if (PID == 0x11) { delayMicroseconds(responsespace); //after PID Tbit space for (int i=0;i<numbers;i++) { Serial1.write(sending[i]); if (interbytespace == 0) { delayMicroseconds(1); } else { delayMicroseconds(interbytespace); } Serial1.write(MessageCRC(message,0)); } } } } } } }
void LinWrite(byte* sending) { Serial1.end(); pinMode(0,OUTPUT); digitalWrite(1, LOW); delayMicroseconds(breakfield*Tbit); //after Frame Error Tbit to Sync Field digitalWrite(1, HIGH); delayMicroseconds(breakdelimiter*Tbit); Serial1.begin(linspeed); Serial1.write(0x55); Serial1.write(0x03); delayMicroseconds(responsespace); for (int i=0;i<numbers;i++) { Serial1.write(sending[i]); if (interbytespace == 0) { delayMicroseconds(1); } else { delayMicroseconds(interbytespace); } } Serial1.write(MessageCRC(sending,0)); } void PrintlnLin() { if(sync != 0) { // Serial.print("Break Field Sync: "); // Serial.print(sync,HEX); Serial.print("PID: "); Serial.print(PID & 0x3F,HEX); //PID without CRC Serial.print(" CRC: "); Serial.print(PIDCRC(PID)); Serial.print(" Message: "); for (int i=0;i<numbers;i++) { Serial.print(message[i],HEX); Serial.print(";"); } Serial.print(" Checksum: "); Serial.print(checksum,HEX); Serial.print(" ChecksumCRC: "); Serial.println(MessageCRC(message,0),HEX); } }
void ClearFrame() { sync = 0; PID = 0; for (int i=0;i<numbers;i++) { message[i] = 0; } checksum = 0; }
void blinking() { unsigned long currentMillis = millis(); if(currentMillis - previousMillis > interval) { // save the last time you blinked the LED previousMillis = currentMillis; // if the LED is off turn it on and vice-versa: if (ledState == LOW) ledState = HIGH; else ledState = LOW; // set the LED with the ledState of the variable: digitalWrite(13, ledState); } }
int PIDCRC(int PID) { int P0 = ((PID>>0) + (PID>>1) + (PID>>2) + (PID>>4)) & 1; int P1 = ~((PID>>1) + (PID>>3) + (PID>>4) + (PID>>5)) & 1; return (P0 | (P1<<1)); }
byte MessageCRC(byte* message, uint16_t sum) { for (int i=0;i<numbers;i++) { sum += message[i]; } while(sum>>8) // In case adding the carry causes another carry sum = (sum&255)+(sum>>8); return (~sum); } And for the Due I have Isolated and changed the Atmel Framework Examplecode. I will attach it but I have at the moment not the time for tests also I had also to comment out the USART1_Handler in the variant.cpp to let it complie proper. B.R. Markus
