Loading...
Pages: 1 [2]   Go Down
Author Topic: External supply at 5v pin  (Read 755 times)
Offline Offline
Edison Member
View Profile
The first photo is the Leonarde R3 board. The soldering is too close to the via. I will redo that when I fix my other Arduino boards.
The diodes don't need to be fast switching, so I used normal 1N4007.
« Last Edit: January 09, 2013, 02:42:17 pm by Krodal » Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
I went back thru my posts from Jan 2011 when I thought this came up (I have 948 pages of posts!) but could not find the original discussion.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
I think that the diode throught the regulator is a good solution. Thanks CrossRoads.
I put a 1N4001 from 5Vpin to 12Vpin.
Logged
Offline Offline
Edison Member
View Profile
Two more photos.
The first photo is the Arduino Nano V3.0.
A 1N4007 was too big for this, so I used a 1N4148. They are only 200mA, but can handle a repetitive peak of 450mA.
I glued the 1N4148 to the board, and after that I soldered it to the voltage regulator.
The second photo is the Arduino Mega.
Next to the ground connection is a smd capacitor. So the diode is up in the air. I used glue for mechanical strength.
Logged
Offline Offline
Newbie
View Profile
Good job Krodal.
Why you didn't use an 1N4001?
Logged
Offline Offline
Edison Member
View Profile
I just grabbed what was lying in my soldering place.
Logged
Siena Italia
Offline Offline
Jr. Member
View Profile
I am wondering whether the caution added for the Uno R3 was really to protect the voltage regulator.  Here's what ON Semiconductor says about this:
Quote
Protection Diodes
The NCP1117 family has two internal low impedance diode paths that normally do not require protection when
used in the typical regulator applications. The first path connects between Vout and Vin, and it can withstand a peak
surge current of about 15 A. Normal cycling of Vin cannot generate a current surge of this magnitude. Only when Vin
is shorted or crowbarred to ground and Cout is greater than 50 F, it becomes possible for device damage to occur.
Under these conditions, diode D1 is required to protect the device.
Given that the VR input on the Arduino board should never go to ground, the built-in protection (15 AMP) seems to me more than adequate.
Perhaps the reason for not wanting you to attach power to the 5V pin is to protect the ATMEGA16 used in place of the USB-Serial converter used on older boards?  If that's the case, your bypass diode cure is worse than the disease!  Perhaps someone involved in Uno R3 development could chime in here.
The Nano doesn't use the Atmega16, and there's a blocking diode between the USB V+ and the 5V line.  That's why the Nano's USB converter can't be powered from Vin, but just from the USB jack, but it also means that externally-supplied power at the 5V pin can't in any way damage it.  TI's data sheet for the UA78M05 makes absolutely no mention of reverse current flow problems.  In other words, for the Nano while a bypass diode probably won't cause any harm, it just doesn't seem to serve any purpose either.
Ciao,
Lenny
Logged
Offline Offline
Newbie
View Profile
I also looked at the NCP1117 datasheet and came to the same conclusion.  With care it should be ok to use +5V pin on the Mega2560.  With care means look at 10 ways to Destroy an Arduino - http://ruggedcircuits.com/html/ancp01.html and dont try any of these!
I also tried for a short period of time to use both external 5v regulator and the USBVCC power with no obvious problems.  It is clear that the USBVCC switch will be switched on because VIN will not have sufficient voltage to switch it off so both USBVCC and the external 5v regulator will be supplying the +5v rail and thats not good and you will need to protect your external regulator.  I would not run with both USBVCC and an external 5v regulator at the same time because you may not be lucky.  Also ensure that you use an isolated external supply because you dont want to have the external supply to have a different ground potential to the USB port.
« Last Edit: April 06, 2013, 03:57:08 pm by peteasa » Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
That is simply not the case. Look at the nano schematic ( http://arduino.cc/en/uploads/Main/ArduinoNano30Schematic.pdf )
The FTDI USB serial converter chip's Vcc pin is powered from the +5 bus, the same as the AVR 328P chip. So the FTDI chip is powered up from either the on-board +5vdc regulator or the VUSB the same as the AVR chip.
Lefty
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
