Hey Community :-)
i was on the search of how to burn bootloaders to fresh microcontrollers.
on the side of the boards it is always linked to
http://arduino.cc/en/Tutorial/Bootloaderbut this side redirects to
http://arduino.cc/en/Guide/Environment?from=Tutorial.Bootloaderi think it should link to the Uploading part in the document:
http://arduino.cc/en/Guide/Environment?from=Tutorial.Bootloader#uploadingIn the Tools Section are also two link pointing to the Tutorial/Bootloader page - that means they pointing to the same document you reading in
Programmer
For selecting a harware programmer when programming a board or chip and not using the onboard USB-serial connection. Normally you won't need this, but if you're burning a bootloader to a new microcontroller, you will use this.
Burn Bootloader
The items in this menu allow you to burn a bootloader onto the microcontroller on an Arduino board....
is there some where some more information on the concept of the bootloaders for the different boards?
sunny greetings
stefan
