Loading...
Pages: [1]   Go Down
Author Topic: Array of functions (addressing multiple identical sensors)  (Read 282 times)
Sydney, AUS
Offline Offline
Newbie
View Profile
Hi all -
I'm trying to build a small temperature monitor, with an UnoR3 and 5 DHT11 temperature/humidity sensors. These are 3-wire digital thingies (5V, GND, data). I'd like to have the code sort-of generic, but can't figure out how to set it up properly.
The library uses something like this (simplified from original example):
Code:
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
#define DHTTYPE DHT11   // DHT 11
DHT dht(DHTPIN, DHTTYPE);
  dht.begin();
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.println(" *C");
DHT is a class for the sensor and defined in the DHT library.
dht(pin,type) is a constructor for the sensor and defined in the DHT library.
This good for one sensor, but now I'd like to do the same for 3 or 4 or 5...
Something like this:
Code:
const int MaxSensors = 5;
DHT myDHT[MaxSensors]; // an array[0..4] of sensors
  for (int n=0; n<MaxSensors-1; n++) {
    myDHT[n] = dht(n, 11); // define a sensor at pin 'n' with sensor type DHT11
void loop(){
  // etc.
However, I can't get this to work. So ...
Given a given class DHT with a constructor dht(pin, type), how do I create an array of sensors with pins 0,1,2,3,4 and type 'whatever' in Arduino ?
Any help is seriously appreciated.
/O.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
How about a link to this DHT library? The one on the playground does not have a class called DHT (it's called dht, and, yes, case matters) nor does it have a two argument constructor.
Edit: You could always add a no-argument constructor and methods to set the pin and type.
Logged
Leeds, UK
Offline Offline
God Member
Once the magic blue smoke is released, it won't go back in!
View Profile
WWW
You could always try this:
Code:
DHT myDHT[MaxSensors] = {DHT(0, 11),DHT(1, 11),DHT(2, 11),DHT(3, 11),DHT(4, 11)};
EDIT: Sorry, those should have been in Capitals, fixed now.
« Last Edit: January 10, 2013, 06:30:29 am by Tom Carpenter » Logged
~Tom~
Sydney, AUS
Offline Offline
Newbie
View Profile
I used the library from Adafruit, on github, see this link https://github.com/adafruit/DHT-sensor-library.
It has a class DHT, not dht. The example there uses dht as the instance, not DHT:
Code:
DHT dht(pin, type);
I've come up with the following, which compiles. Not sure if this is the right way to go, or if it's garbage.
Code:
#include <Arduino.h>
#include <DHT.h>
const int maxDHT = 5;
DHT* myDHT[maxDHT]; // array of 5 pointers to DHTs
void setup(){
  for (int i=0; i<(maxDHT-1); i++) {
    Serial.print(i), Serial.print("\n");
    DHT aDHT(i, 11); //define a new DHT at pin i with type 11;
    myDHT[i]=&aDHT; // store pointer to aDHT in array myDHT at index i
void loop(){
  // do some stuff with it here
Logged
UK
Offline Offline
Tesla Member
View Profile
The simplest approach I can see is to declare an array of pointer-to-dhc and 'new' each dht object in setup.
Code:
int pins[MaxSensors] = { 3, 4, 5, 6, 7 };
DHT *myDHT[MaxSensors];
Code:
for (int n=0; n<MaxSensors; n++)
    myDHT[n] = new DHT(pins[n], 11); // define a sensor at pin 'n' with sensor type DHT11
Code:
  float h = myDHT[n]->readHumidity();
  float t = myDHT[n]->readTemperature();
ETA: If the DHT class has a copy constructor, I think you could also do:
Code:
    DHT(3, 11),
    DHT(4, 11),
    DHT(5, 11),
    DHT(6, 11),
    DHT(7, 11)
« Last Edit: January 10, 2013, 06:26:59 am by PeterH » Logged
Leeds, UK
Offline Offline
God Member
View Profile
WWW
Code:
The problem with that code is that the aDHT instances go out of scope at the end of the for loop and so the array of pointers will become invalid.
Logged
~Tom~
Sydney, AUS
Offline Offline
Newbie
View Profile
Hmmm -- I think I see where you got your Karma from.
It looks like it compiles without errors, now I have this, which compiles without errors:
Code:
#include <DHT.h>
 // DHT aDHT(1,11); // dummy DHT with pin 1 and Type 11
float temp, humid;
void setup(){
    myDHT[i] = new DHT(i, 11); //define a new DHT at pin 11;
void loop(){
    temp=myDHT[i]->readTemperature();
    humid=myDHT[i]->readHumidity();
    delay(2500);
    Serial.print(i), Serial.print(", T = "); Serial.print(temp); Serial.print("\n");
    Serial.print(i), Serial.print(", H = "); Serial.print(humid); Serial.print("\n");
Logged
Sydney, AUS
Offline Offline
Newbie
View Profile
Addendum -
So... contrary to many posts on the web, 'new' *does* exist in avr-gcc (under Arduino-1.0.1 in my case). That makes things a lot easier. It seems the latest version does indeed compile, and code size seems to scale with maxDHT:
maxDHTBytes
56066
66068
76070
86072
n6056+2*n
Thanks for all your help, people!
O.
Logged
New Jersey
Offline Offline
Edison Member
View Profile
Quote
For a long time (prior to IDE version 1.0 I suspect), it didn't - hence the confusion caused by older discussions of the topic.
Logged
UK
Offline Offline
Tesla Member
View Profile
Why are you using 'i<(maxDHT-1)' everywhere? If maxDHT is the number of DHTs then the condition should be 'i < maxDHT'. If it isn't, then perhaps you should be defining some other constant which is.
Logged
Pages: [1]   Go Up
Print
Jump to:
