Topic: adding serial commands to code for remote control (Read 2036 times) previous topic - next topic
capt_carroll
i am a noob and i have some code for my motors but i need help adding serial commands to it so i can transmit from one arduino to another for remote control of motors. could someone please help get me started in the right direction for both the transmitter and receiver, i would greatly appreciate the help.
#include <Stepper.h>
const int stepsPerRevolution = 64;
Stepper pan(stepsPerRevolution, 8,10,9,11);
Stepper tilt(stepsPerRevolution, 3,5,4,6);
  pan.setSpeed(300);
  tilt.setSpeed(300):
  int sensorReading = analogRead(A0); // X-axis
  if (sensorReading < 300) { pan.step(2); }   // left
  if (sensorReading > 800) { pan.step(-2); }  // right
  int sensorReading2 = analogRead(A1); // Y-axis
  if (sensorReading2 < 300) { tilt.step(2); } // down
  if (sensorReading2 > 800) { tilt.step(-2); } // up
thanks for your help
PaulS
Transmit how? How are the Arduino's connected?
Basically, the process is EXACTLY the same as transferring the data to the Serial Monitor, and there are billions of examples of how to do THAT around.
capt_carroll
http://gravitech.us/xbadforarna.html is the sheild im using with an adduino nano and xbees
PaulS
...is the sheild im using with an adduino nano and xbees
With that device, and properly configured XBees, it is a direct replacement for a wire. You'd program the Arduinos just as if they had a wire connecting them.
capt_carroll
That makes a little bit of sense but how you structure the code for the transmitter an receiver ? sorry am a complete noob when it comes to coding...
thanks
PaulS
There is a world of difference between being a noob and being to lazy to try something. There are, as I mentioned, a bazillion examples around of how to output serial data with a wire (USB cable, FTDI cable, whatever). There is NO difference in the code when you use XBees instead of a wire.
capt_carroll
agreed but there is also a difference between being lazy and seeking help because i simply dont understand the serial code tags if you will and due to previous failures i dont want to give up because it is rather interesting process.
PaulS
I have no idea what you mean by "serial code tags". I can't believe that anyone gets past blinking an LED without being able to Serial.print("Some stupid crap");.
Reading serial data, on the other end, is a little harder, but not much.
But, you need to make some attempt, even if it falls flat on its face.
