Topic: battery and charger circuit (Read 644 times) previous topic - next topic
mxing
I'm in need of some help regarding a good way to integrate a proper rechargable battery and of course charger for the arduino.
Has anyone implemented this nicely?  I'm running some LEDs, a 20x4 LCD, and a couple servos and would like to have that continue when the power brick is disconnected, and ultimately for at least 24hrs.
Thanks for any help!
LarryD
I would 1st measure the total current the project is drawing. This will give an idea of the battery capacity needed.  "Integrate" the charger and battery, are you going to use a standalone AtMega chip on its on PCB?
No technical PMs.
The last thing you did is where you should start looking.
cjdelphi
Buy a small 5-7a/h lead acid battery (12v), charge it with any old car charger, use it to power your projects for days on end (if your project permits)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
