Topic: Power supply with Multiple Voltage Out ~ Help (Read 4243 times) previous topic - next topic
JimboZA
Righto, thanks for the warning.
@OP Sorry if we high-jacked your thread, but it's still on topic and hopefully useful to you  :)
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
SirNickity
OP -- is your point here to test a circuit, or as a (semi-)permanent supply for a "production" project?  If it's for testing, I would go the route of the ATX PSU.  If you're looking for something permanent, I would choose something else.
Have you ever built your own?  Is that an option?  I use a linear AC-DC conversion stage with various E-I, toroidal, or PCB-mount transformers, then linear regulators for low-current (less than 500mA) rails.  I'll use switching regulators for 500mA to 5A.  Often when using higher-current devices, regulation isn't as important, so a rectified DC output with adequate filtering is good enough.
