Pages: 1 [2]   Go Down
Author Topic: Power supply with Multiple Voltage Out ~ Help  (Read 486 times)
Johannesburg UTC+2
Righto, thanks for the warning.
@OP Sorry if we high-jacked your thread, but it's still on topic and hopefully useful to you  smiley
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Anchorage, AK
OP -- is your point here to test a circuit, or as a (semi-)permanent supply for a "production" project?  If it's for testing, I would go the route of the ATX PSU.  If you're looking for something permanent, I would choose something else.
Have you ever built your own?  Is that an option?  I use a linear AC-DC conversion stage with various E-I, toroidal, or PCB-mount transformers, then linear regulators for low-current (less than 500mA) rails.  I'll use switching regulators for 500mA to 5A.  Often when using higher-current devices, regulation isn't as important, so a rectified DC output with adequate filtering is good enough.
Pages: 1 [2]   Go Up
