Topic: Pulse/Heartbeat Sensor Problems. (Read 3843 times) previous topic - next topic
Harrison_Rusinyak
Jan 09, 2013, 06:04 am Last Edit: Jan 09, 2013, 09:44 am by Harrison_Rusinyak Reason: 1
Hey Guys,
I'm sort of a newbie to the forum, and to the Arduino board (code managing) as well.
I have been working with the Arduino Uno to complete (for a second time) this project.
I am trying to connect the Pulse Sensor to the Arduino, as well as have the led light up with each heartbeat as well.
I've been pulling out my hair for days trying to find a permutation of coding that works. Initially after I bought the darned sensor -- weeks of code permutations -- I have finally made it working. Some underlying issue with the code was , but I have switched over computers; I have moved; the arduino [somehow] disappeared; I have misplaced the coding.
The code I'm attaching is the bit I'm having trouble with,. I'll supply the entire code in its original format (there are numerous circling the internet). I can't get it work simple and straightforward. Help/Suggestions would be much appreciated.
Thanks in advance.
Code: [Select]
volatile int rate[10];                    // used to get running average of HRV values
volatile unsigned long lastBeatTime = 0;  // used to find the time between beats
volatile int sampleCounter;               // used to determine pulse timing
volatile int runningTotal;                // used to keep track of pulses
volatile boolean firstBeat = true;        // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = true;       // used to seed rate array so we startup with reasonable BPM
void interruptSetup(){
 // Initializes Timer1 to throw an interrupt every 1mS.
 TCCR1A = 0x00; // DISABLE OUTPUTS AND PWM ON DIGITAL PINS 9 & 10
 TCCR1B = 0x11; // GO INTO 'PHASE AND FREQUENCY CORRECT' MODE, NO PRESCALER
 TCCR1C = 0x00; // DON'T FORCE COMPARE
 TIMSK1 = 0x01; // ENABLE OVERFLOW INTERRUPT (TOIE1)
 ICR1 = 8000;   // TRIGGER TIMER INTERRUPT EVERY 1mS
 sei();         // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
// THIS IS THE TIMER 1 INTERRUPT SERVICE ROUTINE.
ISR(TIMER1_OVF_vect){ // triggered every time Timer 1 overflows
 // Timer 1 makes sure that we take a reading every milisecond
 Signal = analogRead(pulsePin);  // read the Pulse Sensor
 sampleCounter++;                // keep track of the time with this variable (ISR triggered every 1mS
 //  NOW IT'S TIME TO LOOK FOR THE HEART BEAT
 int H = sampleCounter-lastBeatTime;      // monitor the time since the last beat to avoid noise
 if ( (Signal > 520) && (Pulse == false) && (H > 500) ){
   // signal surges up in value every time there is a pulse
   Pulse = true;                       // set the Pulse flag when we think there is a pulse
   digitalWrite(13,HIGH);              // turn on pin 13 LED
   HRV = sampleCounter - lastBeatTime; // measure time between beats in mS
   lastBeatTime = sampleCounter;       // keep track of time for next pulse
   if(firstBeat){                      // if it's the first time we found a beat
     firstBeat = false;                // clear firstBeat flag
     return;                           // HRV value is unreliable so discard it
   if(secondBeat){                     // if this is the second beat
     secondBeat = false;               // clear secondBeat flag
     for(int i=0; i<=9; i++){          // seed the running total to get a realisitic BPM at startup
       rate[i] = HRV;
   // keep a running total of the last 10 HRV values
   for(int i=0; i<=8; i++){
     rate[i] = rate[i+1];          // shift data in the rate array and drop the oldest HRV value
 rate[9] = HRV;                    // add the latest HRV to the rate array
 runningTotal = 0;                 // clear the runningTotal variable
   runningTotal += rate[i];        // add up the last 10 HRV values
 runningTotal /= 10;               // average the last 10 HRV values
 BPM = 60000/runningTotal;         // how many beats can fit into a minute? that's BPM!
 QS = true;                        // set Quantified Self flag when beat is found and BPM gets updated.
 // QS FLAG IS NOT CLEARED INSIDE THIS ISR
 if (Signal < 500 && Pulse == true){   // when the values are going down, it's the time between beats
   digitalWrite(13,LOW);               // turn off pin 13 LED
   Pulse = false;                      // reset the Pulse flag so we can do it again!
LarryD
Have you read this?
http://arduino.cc/forum/index.php/topic,97455.0.html
No technical PMs.
The last thing you did is where you should start looking.
JimboZA
There are two threads on this sensor by another member, here and here.
Seems it's not the easiest sensor to get working....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Harrison_Rusinyak
Fixed -- for the most part -- the code for the Pulse Sensor (on my computer setup).
Don't know if there is any extraneous dialogue in the coding.
There is still some noise filtering which blinks chaotically.
Enjoy.
Code: [Select]
int pulsePin = 0;
int blinkPin = 13;
int fadePin = 5;
int fadeRate = 0;
volatile int BPM;
volatile int Signal;
volatile int IBI = 600;
volatile boolean Pulse = false;
volatile boolean QS = false;
volatile unsigned long sampleCounter = 0;
volatile int P =512;
volatile int T = 512;
volatile int thresh = 512;
volatile int amp = 100;
void setup(){
  TCCR2A = 0x02;
  TCCR2B = 0x06;
  OCR2A = 0x7C;
  TIMSK2 = 0x02;
  sei();
void loop(){
ISR(TIMER2_COMPA_vect){
  sampleCounter += 2;
  int N = sampleCounter - lastBeatTime;
    if(Signal < thresh && N > (IBI/5)*3){
      if (Signal < T){
        T = Signal;
    if(Signal > thresh && Signal > P){
        P = Signal;
if (N > 250){
if ( (Signal > thresh) && (Pulse == false) && (N > ((IBI/5)*3) )){
    Pulse = true;
    digitalWrite(blinkPin,HIGH);
    delay(200); //
    IBI = sampleCounter - lastBeatTime;
   if(firstBeat){
      firstBeat = false;
      return;
    if(secondBeat){
      secondBeat = false;
        rate[i] = IBI;
word  runningTotal = 0;
    rate[9] = IBI;
    runningTotal += rate[9];
    runningTotal /= 10;
    QS = true;
  if (Signal < thresh && Pulse == true){
    delay(200); //
    Pulse = false;
    amp = P - T;
    thresh = amp/2 + T;
    P = thresh;
    T = thresh;
if (N > 2500){
    thresh = 512;
    P = 512;
    T = 512;
    firstBeat = true;
    secondBeat = true;
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
