Topic: Dual I2C on Arduino DUE (Read 3371 times) previous topic - next topic
ivanseidel
Hi, i would like to know two things about I2C software on the Arduino DUE:
* How can i init the other I2C port (on pins on 20 and 21)? There is no parameter on the initialization to specify that, and i don't believe that there is two objects (Wire1, Wire2);
* How can i change the speed of the I2C bus? SAM3X ARM Cortex M3 IC supports 400 khz (I2C Fast mode) and also slow mode (100khz), but as i know, there is no configuration for that.
Thanks
Arduino DueTimer | https://github.com/ivanseidel/DueTimer
Arduino Thread | https://github.com/ivanseidel/ArduinoThread
mhanuel26
Hello,
Wire and Wire1 for I2C and I2C1 receptivity.
See Wire.h for details...
Code: [Select]
#if WIRE_INTERFACES_COUNT > 0
extern TwoWire Wire;
#endif
#if WIRE_INTERFACES_COUNT > 1
extern TwoWire Wire1;
#endif
Cheers,
