Topic: Making your own PCBs (Read 3713 times) previous topic - next topic
funkyguy4000
Hello!
I live in the dorms at my university and I'm sick of waiting ages for my PCBs to be made and shipped so I'm itching to start making my own.  But there are a few issues with doing this in a dorm, so I need to know a few things
Note: my university is in northern Wisconsin and right now, everything is covered in snow and ice so I can't really blow fumes out my window.
1) Does using skillet reflow create any fumes?  This is how I would be soldering my components b/c using a wand makes fumes.
2) Does drilling holes in a PCB with a Dremel make any fumes?
3) Does using etching solution or ironing the traces onto the board create any fumes?
As you can tell I'm worried about fumes.  I can't let my fire alarm go off.  I could unplug it, I'm just worried that the one outside my room might go off.
Accelerate to 88 miles per hour.
be80be
Make then in the bathroom with the vent On
funkyguy4000
larryd
For many years, I have done what your are looking at doing and the alarm above my work area has never gone off.
No technical PMs.
The last thing you did is where you should start looking.
rvasque
Visible fumes? Not much... but you can smell it as the flux evaporates.  (depending on the solder paste you used, there may be some fumes.) These won't trigger the fire alarm.
No, but depending on the number of holes you're drilling, you can create a lot of dust... and PCB dust has a distinct smell.
No fumes. Now with etching, assuming you're using Ferric Chloride, you may not just be able to dump them in the sink without getting in trouble. ... if you drip/drop the FeCl, it will also cause stains.
CrossRoads
#5
Jan 09, 2013, 04:53 am Last Edit: Jan 09, 2013, 04:55 am by CrossRoads Reason: 1
"I'm sick of waiting ages for my PCBs to be made and shipped"
Use the DHL $26 option.
Build up boards using wirewrap.
Use an American source:  http://www.4pcb.com/  "WE WILL MEET OR BEAT ANY U.S. PRODUCTION PRICE!"
Is there a Chemistry lab with hooded vents you could use?
funkyguy4000
Hmm, I could use a chemistry lab fume hood.  That would work! Looks like I'll be reconnecting with my chemistry professor from freshman year!
liuzengqiang
I would get started with a second project PCB design while waiting for the PCB of the first project. Do some programming, write documentation, answer questions, etc.
bot-thoughts
You might look for some of the domestic bare bones PCB fab options ...  I'm still looking for faster turnaround that doesn't cost a fortune.
Yeah, skillet and soldering and etching all create some crazy nasty fumes. I etch my boards in a plastic food container with the lid on. It minimizes fumes a little. If you're in college, maybe see about making some friends who have access to lab environments where you could borrow a small corner near a vent from time to time?
Once you get in an apartment it gets easier I would think. :)
http://www.bot-thoughts.com/
funkyguy4000
Yea, it should get easier soon.  I've signed a lease on the rent for a house next year but I just don't want to wait that long.
Oh wow 2:40 already?  I need to get to bed.
SirNickity
I read on Adafruit that cutting/drilling PCBs with a fiberglass substrate is dangerous because of carcinogenic dust.  I didn't think of that the first two times I took a Dremel cutting wheel to a panel to split some boards apart.  But now, I don a dust mask with a damp paper towel underneath it.  I may be over-reacting, but I do enough vaguely unhealthy stuff (woodwork, soldering, etc..) that it could add up, and I'm not all that crazy about the idea of catching the cancer.
liuzengqiang
Yes, fiber dust is pretty bad so are solder/copper/paint dusts. I would not do PCB cutting or drilling unless I am protected. A vented hood would be best.
funkyguy4000
Oh, I didn't know that those were carcinogenic.  Looks like i'm gonna need surgery in 30 years.
I'll start using a fume hood.
bot-thoughts
Between the FR4 particles, lead solder, rosin fumes, acetone, gasoline, and various other things this might be my last post. Seriously tho the pcb dust is awful. I won't be cutting or grinding any more of those without a good dust mask / respirator thingy.
westfw
Might as well look for gold - is there an engineering lab where they have PCB fabrication tools?
How about a student machineshop/makerspace?
