MrKovacic:
I'll start by saying this, im pretty good with Autoit, but a baby when it comes to C++..
I have a decent script set up to blink LED's using an old blu-ray player remote. As it stands, the remote has numbered buttons, volume buttons etc.. It also has a red, green, blue and yellow button. I have it so if I push the R, G or B button, the LED of that color lights up. If I push Yellow, it shuts everything off. I am trying to incorperate fading into this, and while it will being and run the fade, it will no longer pay attention to the IR remote during the fade. I tried removing all delays, and even adding in some calls to read the IR, but no matter what I do, the Fade codes stay going until I reset the Arduino.
I have a simple blink on button 2, a fairly simple fade using cos on button 1, and a more advanced fade on button 7.
While any of the fades are going, I can't get Arduino to check the IR for changes.
here is the code:
// include some junk
#include <IRremote.h>
int RECV_PIN = 11;
int periode = 2000;
int displace = 500;
int testtime = 1000;
long time=0;
/* FUTURE USE
int RED1 = 2;
int GREEN1 = 3;
int BLUE1 = 4;
int RED2 = 5;
int GREEN2 = 6;
int BLUE2 = 7;
int RED3 = 8;
int GREEN3 = 9;
int BLUE3 = 10;
int RED4 = 11;
int GREEN4 = 12;
int BLUE4 = 13;
int redPin = 7; // Red LED, connected to digital pin 9
int grnPin = 6; // Green LED, connected to digital pin 10
int bluPin = 8; // Blue LED, connected to digital pin 11
int value, value2, value3 ;
int RED = 7;
int GREEN = 6;
int BLUE = 8;
// Color arrays
int black[3] = { 0, 0, 0 };
int white[3] = { 100, 100, 100 };
int red[3] = { 100, 0, 0 };
int green[3] = { 0, 100, 0 };
int blue[3] = { 0, 0, 100 };
int yellow[3] = { 100, 100, 0 };
int pink[3] = { 0, 100, 100 };
int magenta[3] = { 100, 0, 100 };
// etc.
// Set initial color
int redVal = black[0];
int grnVal = black[1];
int bluVal = black[2];
//int wait = 2; // no longer used
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
IRrecv irrecv(RECV_PIN);
decode_results results;
long previousMillis = 0;
long interval = 1000;
long chill = 2;
int ledState = LOW; // only for BLUE LED for now, will add more later, just want to blink blue for now
int blinkone = 0;
int blinktwo= 0;
int blinkthree = 0;
int blinkfour = 0;
int blinkfive = 0;
int blinksix = 0;
int blinkseven = 0;
int blinkeight = 0;
int blinknine = 0;
void setup() //Just some obvious crap
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
irrecv.enableIRIn(); // kick on the IR receiver
unsigned long currentMillis = millis(); // Start the arduino counting so it can keep time
if (irrecv.decode(&results)) {
if (results.value == 0x66B47) { // BLUE button on the remote
digitalWrite(BLUE, HIGH);
else if (results.value == 0xE6B47) { // RED button on the remote
digitalWrite(RED, HIGH);
else if (results.value == 0x490) { // Vol Up button on the remote
interval = interval - 50;
if (interval < 75) {
interval =100;
else if (results.value == 0xC90) { // Vol Down button on the remote
interval = interval + 50;
else if (results.value == 0x290) { // Vol Down button on the remote
interval = 1000;
else if (results.value == 0x16B47) { // GREEN button on the remote
digitalWrite(GREEN, HIGH);
else if (results.value == 0xB47) { // 1 button on the remote
while (results.value == 0xB47) {
time = millis();
value = 128+127cos(2PI/periodetime);
value2 = 128+127cos(2PI/periode(displace-time));
value3 = 128+127cos(2PI/periode*(testtime-time));
analogWrite(redPin, value); // sets the value (range from 0 to 255)
analogWrite(grnPin, value2); // sets the value (range from 0 to 255)
analogWrite(bluPin, value3);
irrecv.resume();
else if (results.value == 0x80B47) { // 2 button on the remote
blinkone = 1;
blinktwo= 0;
blinkthree = 0;
blinkfour = 0;
blinkfive = 0;
blinksix = 0;
blinkseven = 0;
blinkeight = 0;
blinknine = 0;
} else if (results.value == 0x40B47) { // 3 button on the remote
blinkone = 0;
blinktwo= 0;
blinkthree = 1;
blinkfour = 0;
blinkfive = 0;
blinksix = 0;
blinkseven = 0;
blinkeight = 0;
blinknine = 0;
} else if (results.value == 0xC0B47) { // 4 button on the remote
blinkone = 0;
blinktwo= 0;
blinkthree = 0;
blinkfour = 1;
blinkfive = 0;
blinksix = 0;
blinkseven = 0;
blinkeight = 0;
blinknine = 0;
} else if (results.value == 0x20B47) { // 5 button on the remote
blinkone = 0;
blinktwo= 0;
blinkthree = 0;
blinkfour = 0;
blinkfive = 1;
blinksix = 0;
blinkseven = 0;
blinkeight = 0;
blinknine = 0;
} else if (results.value == 0xA0B47) { // 6 button on the remote
blinkone = 0;
blinktwo= 0;
blinkthree = 0;
blinkfour = 0;
blinkfive = 0;
blinksix = 1;
blinkseven = 0;
blinkeight = 0;
blinknine = 0;
} else if (results.value == 0x60B47) { // 7 button on the remote
while (results.value == 0x60B47) {
crossFade(red);
crossFade(green);
crossFade(blue);
crossFade(yellow);
crossFade(white);
crossFade(pink);
crossFade(magenta);
} else if (results.value == 0xE0B47) { // 8 button on the remote
blinkone = 0;
blinktwo= 0;
blinkthree = 0;
blinkfour = 0;
blinkfive = 0;
blinksix = 0;
blinkseven = 0;
blinkeight = 1;
blinknine = 0;
} else if (results.value == 0x10B47) { // 9 button on the remote
blinkone = 0;
blinktwo= 0;
blinkthree = 0;
blinkfour = 0;
blinkfive = 0;
blinksix = 0;
blinkseven = 0;
blinkeight = 0;
blinknine = 1;
else if (results.value == 0x96B47 ) { // YELLOW - shut everything off. aka blackout
digitalWrite(BLUE, LOW);
digitalWrite(RED, LOW);
digitalWrite(GREEN, LOW);
blinkone = 0; // stops that pesky blue light from blinking like a little bitch
irrecv.resume(); //doesnt matter where you put this, it workd right here so I guess dont mess with it
if (blinkone == 1) { // First flash pattern. On and off, bow to its awesomeness!
if(currentMillis - previousMillis > interval) {
previousMillis = currentMillis;
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
digitalWrite(BLUE, ledState);
} //include this
int calculateStep(int prevValue, int endValue) {
int step = endValue - prevValue; // What's the overall gap?
if (step) { // If its non-zero,
step = 1020/step; // divide by 1020
return step;
int calculateVal(int step, int val, int i) {
if ((step) && i % step == 0) { // If step is non-zero and its time to change a value,
if (step > 0) { // increment the value if step is positive...
val += 1;
else if (step < 0) { // ...or decrement it if step is negative
val -= 1;
// Defensive driving: make sure val stays in the range 0-255
if (val > 255) {
val = 255;
else if (val < 0) {
val = 0;
return val;
void crossFade(int color[3]) {
// Convert to 0-255
int R = (color[0] * 255) / 100;
int G = (color[1] * 255) / 100;
int B = (color[2] * 255) / 100;
int stepR = calculateStep(prevR, R);
int stepG = calculateStep(prevG, G);
int stepB = calculateStep(prevB, B);
for (int i = 0; i <= 1020; i++) {
redVal = calculateVal(stepR, redVal, i);
grnVal = calculateVal(stepG, grnVal, i);
bluVal = calculateVal(stepB, bluVal, i);
analogWrite(redPin, redVal); // Write current values to LED pins
analogWrite(grnPin, grnVal);
analogWrite(bluPin, bluVal);
int zag = 1;
do {
zag = zag + 1;
getIR();
} while (zag < 200);
// Update current values for next loop
prevR = redVal;
prevG = grnVal;
prevB = bluVal;
void getIR() {
decode_results nresults;
Any help would be very appreciated! :astonished:
