Loading...
Pages: 1 [2] 3   Go Down
Author Topic: cannot read the data from arduino to the c#  (Read 2063 times)
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
that's means it will not read the data into gui?
No it will read data if you send it data and if you write the code correctly.
Logged
Offline Offline
Newbie
View Profile
PaulS, my problem now, the serialport is open..however the data cannnot be uploaded in the WPF?
if every function im doing the threading part..is it works to received the data in synchronous manner?
im handle the serial port class in one threads and the data in another threads..
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Did you try running my application? Did you look at how it handles the serial data in one thread and communicates with the GUI thread?
Logged
Offline Offline
Newbie
View Profile
yes.n i have take a look on the threading..when i click on the button..it says "The port is already open". However there is no data appeared on the WPF.it appeared in the console application and arduino serial monitor but not in the WPF C# application.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Are you trying to run my application and the serial monitor at the same time?
If my application can't open the serial port, is it any wonder why no serial data appear on the form?
Logged
Offline Offline
Newbie
View Profile
there's an error " Couldn't find input file"Properties\Resources.resx.what thats mean?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
p
The file is in the zip file I attached.
Logged
Offline Offline
Newbie
View Profile
yes.i have extracted the file..
Logged
Offline Offline
Newbie
View Profile
the result of the code is appeared in the serial monitor of the arduino and on the console application...however the data is not appeared on the windows form? is there any wrong with my code?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
When I click on the zip file, I get:
Quote
Error 503 Service Unavailable
Service Unavailable
Guru Meditation:
XID: 1078454701
Varnish cache server
So, if you could please varnish the cache server again, that would be good.
Logged
Offline Offline
Newbie
View Profile
hi PaulS, attached is my code that will received the arduino data.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Can't read them, either. I posted in Website and Forum about the problem. When the new coat of varnish dries, I'll try again.
Logged
Indiana
Offline Offline
Jr. Member
View Profile
Let me make sure I understand correctly.
1. Your Arduino is running code outputting data to serial port.
2. You want the data Arduino is sending to serial port to be read into your C# program and displayed on a Windows Form.
I think you have your read and write backwards.  You aren't trying to WRITE the output from serial to your C# GUI, you want to READ the output from Arduino, into your C# program and then display it in the GUI.
set a string variable in C# = sp1.readline()
Then set the GUI element ".TEXT" field = to the string variable you created to display it.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Simple serial monitor test code that sends back what is sent to the arduino. If this works, then the issue is with your pc code. If your pc code opens/closes the pc com port on each write, that will cause the arduino to reset each write.
Code:
// zoomkat 7-30-11 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
  Serial.println("serial test 0021"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(2);  //delay to allow byte to arrive in input buffer
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    readString="";
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
you are right ,jjspierx
im just receiving the latitude sent by the transmitter and display on GUI.does the code for dispalying the latlong making any sense?
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
