Pages: [1] 2 3   Go Down
Author Topic: cannot read the data from arduino to the c#  (Read 2045 times)
here is my program is c#
   public bool Connect()
        button1.Enabled = false;
            try
                SP1.Open();
            catch (Exception)
                MessageBox.Show("Invalid Serial Port");
                return false;
            if (SP1.IsOpen)
                System.Threading.Thread.Sleep(500);
                string data = SP1.ReadExisting();
                SP1.WriteLine(data);
however i cannot receive the data from arduino through serial port into the c#..how the readexisting functions?does the writeline function enable the data to be write into the c#?sorry,im new in c# and arduino.hope all of u can help.
Manchester (England England)
Online Online
Solder is electric glue
Not done any C# myself but I can't help but notice that no where do you specify the baud rate. You need to do that so look at the C# manure to tell you how to do it.
Get Bitlash: http://bitlash.net
I have heard many terms for documentation before, but surely this is the most accurate.
arduino_learners: in addition to the baud rate you probably have to tell it which COM: port to use.
For what it's worth, there is a little C# info here in the Playground:
    http://playground.arduino.cc/Interfacing/csharp
-br
i have initialized the serial port.
SP1 = new SerialPort("COM3" ,9600,Parity.None,8,StopBits.One);
Seattle, WA USA
Seattle, WA USA
Which Arduino are you using?
arduino uno r3 compatible.
Seattle, WA USA
Seattle, WA USA
This is what the first part of my connect button's callback code looks like:
private void connect_Click(object sender, EventArgs e)
System.ComponentModel.IContainer components =
new System.ComponentModel.Container();
port = new System.IO.Ports.SerialPort(components);
port.PortName = comPort.SelectedItem.ToString();
port.BaudRate = Int32.Parse(baudRate.SelectedItem.ToString());
port.DtrEnable = true;
port.ReadTimeout = 5000;
port.WriteTimeout = 500;
port.Open();
The form has drop down lists for the com port and baud rate.
With this code, I'm able to send to/read from all the Arduinos I have (Mega, Leonardo, and Duemilanove).
(port is a global instance of the SerialPort class.)
so the coding for writeline and readline cannot read the data from arduino?
Seattle, WA USA
Seattle, WA USA
I don't understand this statement/question. Of course it is possible to write to the serial port that the Arduino is connected to, and read from that serial port.
Of course, the Arduino must be sending data for there to be something to read and the Arduino must be reading the data for there to be a reason to send it.
You seem to have nothing on the PC end more than an echoer of what the Arduino sent, so, how do you know it isn't working?
i am able to receive the da ta on the arduino because i have check it using the SerialMonitor of the arduino.however, i cannot get those data received to be transferred to  my GUI using c#.nothing appeared on the GUI side.
Seattle, WA USA
Seattle, WA USA
That is MUCH different that what you were first complaining about. The serial data is handled in one thread. The GUI is handled in another thread.
The attached application creates a new thread to handle the serial data, and appropriate methods to share data between threads. Perhaps you could study it.
Online Online
Yes the auto corrector on the iPad strikes again.  smiley smiley
But as you say it is most appropriate.
Seattle, WA USA
Seattle, WA USA
Hey, now. If you've never used C#, how do you know that?
Well, aside from the fact that it is from miCroSofT, to whom case is irrelevant.
Online Online
Because I have heard engineers working for me deride it and call it "I can't believe it's not Java"
and yes it's from Micro$oft.
that's means it will not read the data into gui?
Pages: [1] 2 3   Go Up
