Loading...
Pages: [1]   Go Down
Author Topic: DC Auto-Iris control for CCTV lens  (Read 1989 times)
Offline Offline
Newbie
View Profile
I am looking to build a circuit to control the iris of a cctv lens. The input of that lens is a DC auto-iris type which is: pin 1: Damping- , pin2 Dampining+, pin3 Drive+, Pin4 Drive-.
Here is a link on how dc auto-iris work http://www.gevicam.com/images/ED-_TN-07001AI_lens.pdf
I can make a circuit to control the iris manually but it is not practical adjust it for all lighting conditions.
Generally, CCTV uses the output of the video signal to adjust the iris opening size. How do I go about building such circuit for auto-light balancing?
This is part of my other project to use Arduino to control a manual zoom lens. I know how I can attach and control the zoom with servos but the iris part seems to cause me problems.
Logged
Offline Offline
Newbie
View Profile
Anyone?
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Simulate a sync-less video signal with PWM and a low-pass filter?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Generating a pwm will be to control the opening and close of iris but I want it to automatically responce to the brightness of the video signal, like too bright then close the iris more etc
I can send the video signal through a low-pass filter cut off at around 2MHz-2.5Mhz to extract the lumanace signal and using that to feed to the control mechanism. It is that control machanism that I want to know how to use the camping signal to feedback to the drive signal.
« Last Edit: October 28, 2011, 12:29:20 pm by kkman20xx » Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
The problem is that the camera will have some AGC (automatic gain control)  that will mess up control. Maybe a peak detector feeding into the analogue input would work.
Then just use a nudge loop to control the iris.
Logged
Offline Offline
Newbie
View Profile
It is a simple board camera and I doubt it has AGC. What do you mean by nudge loop?
Logged
Offline Offline
Brattain Member
View Profile
WWW
It will be the first video circuit I have seen without AGC.
A nudge loop is one where you look at the input and decide if it is larger than or smaller than the required value, and then nudge (change the output value (iris size) ) in the appropriate direction. Repeat it often enough and it converges on the correct setting.
Logged
Offline Offline
Newbie
View Profile
Just checked camera spec, it has AGC, damn it.
Logged
Offline Offline
Newbie
View Profile
2 Ideas:
1. Use an electronic light measuring method (like http://www.sparkfun.com/products/8940 or http://www.sparkfun.com/products/8688) and use the Arduino to adjust the iris of the camera in relation to the measured ambient light.
2. Use an Elphel camera ( http://www3.elphel.com ) and interface it with the Arduino (like http://wiki.elphel.com/index.php?title=Arduino ). That way you have full histogram access and can adjust the iris accordingly.
Logged
Offline Offline
Newbie
View Profile
Hello kkman20xx,
You said: "I can make a circuit to control the iris manually"
I' like to make a circuit just like that. Would you please share the corresponding circuit diagram?
Regarding your original question, I found this paper: http://ecad.tu-sofia.bg/et/2005/pdf/Paper101-T_Djamiykov1.pdf. If you write them, they might help you. Thanks and good luck!
Logged
Offline Offline
Newbie
View Profile
did u finish ur project. i also have to do the same. pls share informations
Logged
Pages: [1]   Go Up
Print
Jump to:
