Topic: Arduino mini, pro mini power consumption (Read 73136 times) previous topic - next topic
tim7
The power LED draws about 0.2mA; the remainder is drawn by the regulator.
Lahorde
Very interesting post.
Here is my contribution, I use an Arduino Mini powered at VCC Pin with 3,7V.
My consumption is about 2.4mA by using following sleep code :
void sleepPwrDown(uint8_t wdt_period) {
  wdt_enable(wdt_period);
  wdt_reset();
  WDTCSR |= _BV(WDIE);
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  power_adc_disable();
  power_spi_disable();
  power_timer0_disable();
  power_timer1_disable();
  power_timer2_disable();
  power_twi_disable();
  sleep_mode();
  wdt_disable();
  WDTCSR &= ~_BV(WDIE);
Here are hardware schematics :
http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Dev/Arduino/Boards/Arduino-Pro-Mini-v13.pdf
http://arduino.cc/en/uploads/Main/arduino_mini_schematic05.pdf
According to measures given previously for ProMini, consumption on Mini seems excessive.
Does it comes from
- 16Mhz ATmega 328 frequency?
- regulator? in both cases it is not used (on my Mini Arduino nothing is connected on 9V Pin)
-other circuitry?
Any help appreciated. Thanks.
tim7
The power LED on the Arduino Mini is driven via a 1k resistor, whereas the ProMini has a 10k resistor.  That probably accounts for the difference.  To get really low power consumption you'll need to disconnect the LED and regulator.
Lahorde
#18
Nov 22, 2013, 06:04 pm Last Edit: Nov 22, 2013, 06:20 pm by Lahorde Reason: 1
Tim7,
No more LED! 1K resistance does the difference, I decrease consumption of ~2mA ! No I'm below I'm in hundreds of µAmp domain!
Cheers
richardtheboffin
I'm doing the same experiments here with a pro mini and an nRF24l01 radio.
I'm also experimenting with a boost converter which will go from 0.9V to 5V in and give 5V out.
I have a 5v pro mini which means I have to waste some power with a 3.3v regulator for the radio. The PIR I have needs 5v so I can't go all 3.3v.
Running as standard I get 18mA on the pro mini and 15mA to the radio.
I tried moving the 5v input from RAW to VCC and actually saw an increase of just over 1mA so I will take a look at disabling the regulator and power leds next.
richardtheboffin
I took off the power led, powered the radio from a port pin and wake from power down when the PIR goes off, and got the power consumption down to 90uA in sleep. (this is still via the onboard regulator)
I have a boost converter attached to get 5V from a 1.5V battery (it will give 5V from 0.9v to 5V in) and with this attached I get a total power consumption of 470uA in sleep mode so the psu is taking 380uA to sit idle.
I does mean I can run off a single AA for quite a while (243 days) and they are a lot cheaper than 9V PP3 batteries. If I wanted a bigger finished unit, I could run everything off of 3XAA's for a very long time. (3 and a half years)
Ideally I would have a periodic transmission just to make sure the sensor is still going, so I guess 70mA for 150mS every minute maybe.
Lahorde
Just other info... With my Arduino Mini, I had removed power LED and was sleeping in In SLEEP_MODE_PWR_DOWN with ADC and brown out detector disabled
=> 438µA consumption @ 4.5V
now I removed regulator
=>5.5µA @4.5V
I used a useful library for putting ATmega328p in low power :
https://github.com/rocketscream/Low-Power
Lahorde
