South Africa
Offline
Newbie
« Reply #30 on: January 10, 2013, 07:48:15 am » |
very sorry,ok will post all info,display on my serial monitor continuesly reading,but doesnt read any sms's data: [] AT+CMGR data: [] AT+CMGR data: [] AT+CMGR data: [] AT+CMGR data: [] AT+CMGR data: [] AT+CMGR data: [] sketch int led = 13; int onModulePin = 9; // the pin to switch on the module (without press on button)
int timesToSend = 1; // Numbers of SMS to send int count = 0;
int n_sms,x,sms_start; char data[256];
void switchModule(){ digitalWrite(onModulePin,HIGH); delay(2000); digitalWrite(onModulePin,LOW); }
void setup(){
Serial.begin(19200); // UART baud rate delay(2000); pinMode(led, OUTPUT); pinMode(onModulePin, OUTPUT); switchModule(); // switches the module ON
delay(5000);
Serial.println("AT+CMGF=1"); // sets the SMS mode to text
delay(1000); }
void loop(){
Serial.println("AT+CMGR"); //Reads the first SMS
while(Serial.available()==0);
Serial.print("data: ["); Serial.print(data); //shows the message Serial.println("]"); if(strcmp(data, "on") == 0) { Serial.println("Turning LED on"); digitalWrite(led,HIGH); } if(strcmp(data, "off") == 0) { Serial.println("Turning LED off"); digitalWrite(led,LOW); // Turn the pin off
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #31 on: January 10, 2013, 07:50:03 am » |
Serial.print("data: ["); Serial.print(data); //shows the message Serial.println("]"); if(strcmp(data, "on") == 0) { Serial.println("Turning LED on"); digitalWrite(led,HIGH); } Send a command. Wait until there is a reply. Ignore the reply. Expect, magically, the data to have been read anyway. Can anyone else see a problem with this? What happened to the code to actually read the reply?
Logged
South Africa
Offline
Newbie
« Reply #32 on: January 10, 2013, 07:58:37 am » |
ok,this is my full code,does not loop when checking for sms's, int led = 13; int onModulePin = 9; // the pin to switch on the module (without press on button)
void setup(){
for (int i=0;i < 5;i++){ delay(5000); }
delay(1000); }
void loop(){
Serial.flush(); for (x=0;x < 255;x++){ data[x]='\0'; } x=0; do{ while(Serial.available()==0); data[x]=Serial.read(); x++; if(data[x-1]==0x0D&&data[x-2]=='"'){ x=0; } } while(!(data[x-1]=='K'&&data[x-2]=='O'));
data[x-3]='\0'; //finish the string before the OK Serial.print("data: ["); Serial.print(data); //shows the message Serial.println("]"); if(strcmp(data, "on") == 0) { Serial.println("Turning LED on"); digitalWrite(led,HIGH); } if(strcmp(data, "off") == 0) { Serial.println("Turning LED off"); digitalWrite(led,LOW); // Turn the pin off
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #33 on: January 10, 2013, 08:03:33 am » |
ok,this is my full code,does not loop when checking for sms's, What output do you get? Why is that Serial.flush() back? GET RID OF IT!!!
Logged
South Africa
Offline
Newbie
« Reply #34 on: January 10, 2013, 08:13:23 am » |
stops checking after ; AT+CMGF=1 AT+CMGR
void setup(){
delay(1000); }
void loop(){
Serial.println("AT+CMGR=1"); //Reads the first SMS
« Last Edit: January 10, 2013, 08:19:48 am by kevin-se »
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #35 on: January 10, 2013, 08:38:32 am » |
stops checking after ; You don't know that. All you know is that your reading loop never ends. So, what is happening in that loop? for (x=0;x < 255;x++){ data[x]='\0'; } If you understood C strings, you'd know why this was unnecessary. data[0] = '\0'; is all that is needed. Make some changes. x=0; do{ while(Serial.available()==0); data[x++]=Serial.read(); data[ x ] = '\0'; // Keep string NULL terminated if(data[x-1]==0x0D&&data[x-2]=='"') { // Down here where it belongs! x=0; data[ 0 ] = '\0'; } Serial.print("data: ["); Serial.print(data); Serial.println("]"); } while(!(data[x-1]=='K'&&data[x-2]=='O')); Show us the output (and the code).
« Last Edit: January 10, 2013, 08:40:34 am by PaulS »
Logged
South Africa
Offline
Newbie
« Reply #36 on: January 10, 2013, 08:40:45 am » |
with some modifications,seems to read sms and then stops,dont know why the loop stops checkin AT+CMGF=1 AT+CMGR=1 data: [ ON ]
] AT+CMGR=1
void setup(){
delay(1000); }
void loop(){
Serial.println("AT+CMGR=1"); //Reads the incoming SMS's
Serial.println("AT+CMGD=1,2"); //Deletes all recieved sms's only
Logged
South Africa
Offline
Newbie
« Reply #37 on: January 10, 2013, 10:56:13 am » |
ok,additions to the code,have to concentrate on reading the serial correctly, the code continues to check for new sms's but its not in a format i understand and the module switches itself off after a few minutes,below the output then switches off, data: [ NORMAüAT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿÿ] data: [ÿÿÿ] data: [ÿÿÿÿ] data: [ÿÿÿÿ ] data: [ÿÿÿÿ ] data: [ÿÿÿÿ R] data: [ÿÿÿÿ RD] data: [ÿÿÿÿ RDY] data: [ÿÿÿÿ RDY ] data: [ÿÿÿÿ RDY ] data: [ÿÿÿÿ RDY
] data: [ÿÿÿÿ RDY
] data: [ÿÿÿÿ RDY
+] data: [ÿÿÿÿ RDY
+C] data: [ÿÿÿÿ RDY
+CF] data: [ÿÿÿÿ RDY
+CFU] data: [ÿÿÿÿ RDY
+CFUN] data: [ÿÿÿÿ RDY
+CFUN:] data: [ÿÿÿÿ RDY
+CFUN: ] data: [ÿÿÿÿ RDY
+CFUN: 1] data: [ÿÿÿÿ RDY
+CFUN: 1 ] data: [ÿÿÿÿ RDY
+CFUN: 1
] data: [ÿÿÿÿ RDY
+CFUN: 1
] data: [ÿÿÿÿ RDY
+CFUN: 1
+] data: [ÿÿÿÿ RDY
+CFUN: 1
+C] data: [ÿÿÿÿ RDY
+CFUN: 1
+CP] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPI] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN:] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: R] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: RE] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: REA] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CFUN: 1
+CPIN: READY
] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
C] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Ca] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Cal] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call R] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Re] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Rea] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Read] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Call Ready A] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+C] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CM] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMG] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 A] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+C] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CM] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMG] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 d] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 da] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 dat] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data:] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ]] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] d] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] da] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] dat] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data:] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿÿ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿÿ]] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿÿ] ] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿÿ] d] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿÿ] da] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿÿ] dat] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] data: [ÿÿ] data] data: [ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 data: [ÿ] sketch int led = 13; int onModulePin = 9; // the pin to switch on the module (without press on button)
void setup(){
delay(1000); }
void loop(){
Serial.println("AT+CMGR=1"); //Reads incoming sms
x=0; do{ while(Serial.available()==0); data[x++]=Serial.read(); data[ x ] = '\0'; if(data[x-1]==0x0D&&data[x-2]=='"') { x=0; data[ 0 ] = '\0'; } Serial.print("data: ["); Serial.print(data); Serial.println("]");
Serial.println(data); //shows the message
delay(5000);
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #38 on: January 10, 2013, 03:20:09 pm » |
x=0; do{ } while(!(data[x-1]=='K'&&data[x-2]=='O')); How valid do you suppose -1 and -2 are as indices into data? You really need to ditch the do/while loop, and use some other construct to wait for data, and then read all data until OK appears. But, before you get started on that, think about what happens if the AT command fails, and the return does NOT include OK.
Logged
South Africa
Offline
Newbie
« Reply #39 on: January 11, 2013, 08:59:31 am » |
hi ,been trying to modify the code for many hours but no matter what i add or modify always end up with incorrect readings,tried reading up on strings and used them without any luck,all i have is this perfect code for reading sms's but not been able to use output data, int led = 13; int onModulePin = 9; // the pin to switch on the module (without press on button)
void setup(){
Serial.println("AT+CMGF=1"); // sets the SMS mode to text delay(1000); }
void loop(){ Serial.println("AT+CMGR=1"); //Reads the first SMS x=0; do{ while(Serial.available()==0); data[x]=Serial.read(); x++; if(data[x-1]==0x0D&&data[x-2]=='"'){ x=0; } }while(!(data[x-1]=='K'&&data[x-2]=='O'));
delay(5000);
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #40 on: January 11, 2013, 09:42:48 am » |
all i have is this perfect code x=0; do{ }while(!(data[x-1]=='K'&&data[x-2]=='O'));
When x is 0, as it is initially, it gets incremented to 1 inside the body of the do/while statement. Then, at then end you check the values in data[ 0 ] and data[ -1 ], to see if they are O and K. And, you call code that references an invalid element of the array "perfect". I don't think so. Add the if(strcmp(data, "on") == 0) block to that code. After the if block, print data again. With the '[' before and ']' after it. Does data get corrupted by the strcmp() call?
Logged
South Africa
Offline
Newbie
« Reply #41 on: January 11, 2013, 10:00:16 am » |
hi sir, not sure if its done correctly but there's my attempt, yes the data does get corrupted. int led = 13; int onModulePin = 9; // the pin to switch on the module (without press on button)
void setup(){
delay(1000); }
void loop(){
x=0; do{ while(Serial.available()==0); data[x]=Serial.read(); x++; if(data[x-1]==0x0D&&data[x-2]=='"'){ x=0; } if(strcmp(data, "on") == 0) Serial.print("data: ["); Serial.print(data); Serial.println("]"); } while(!(data[x-1]=='K'&&data[x-2]=='O'));
delay(5000);
} AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ] ÿÿÿÿ] ÿÿÿÿ ] ÿÿÿÿ ] ÿÿÿÿ R] ÿÿÿÿ RD] ÿÿÿÿ RDY] ÿÿÿÿ RDY ] ÿÿÿÿ RDY ] ÿÿÿÿ RDY
] ÿÿÿÿ RDY
] ÿÿÿÿ RDY
+] ÿÿÿÿ RDY
+C] ÿÿÿÿ RDY
+CF] ÿÿÿÿ RDY
+CFU] ÿÿÿÿ RDY
+CFUN] ÿÿÿÿ RDY
+CFUN:] ÿÿÿÿ RDY
+CFUN: ] ÿÿÿÿ RDY
+CFUN: 1] ÿÿÿÿ RDY
+CFUN: 1 ] ÿÿÿÿ RDY
+CFUN: 1 ] ÿÿÿÿ RDY
+CFUN: 1
] ÿÿÿÿ RDY
+CFUN: 1
] ÿÿÿÿ RDY
+CFUN: 1
+] ÿÿÿÿ RDY
+CFUN: 1
+C] ÿÿÿÿ RDY
+CFUN: 1
+CP] ÿÿÿÿ RDY
+CFUN: 1
+CPI] ÿÿÿÿ RDY
+CFUN: 1
+CPIN] ÿÿÿÿ RDY
+CFUN: 1
+CPIN:] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: R] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: RE] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: REA] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY ] ÿÿÿÿ RDY
+CFUN: 1
+CFUN: 1
+CPIN: READY
] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
C] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Ca] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Cal] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call R] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Re] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Rea] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Read] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Call Ready A] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+C] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CM] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMG] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 A] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+C] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CM] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMG] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ]] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ]] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ]] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ] ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ] ÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ] ÿÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ] ÿÿÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ] ÿÿÿÿ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ] ÿÿÿÿ]] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
Call Ready AT+CMGF=1 AT+CMGR=1 ÿ] ÿÿ] ÿÿÿ] ÿÿÿÿ] ] ÿÿÿÿ RDY
+CFUN: 1
+CPIN: READY
+CFUN: 1
+CPIN: READY
Logged
South Africa
Offline
Newbie
« Reply #42 on: January 11, 2013, 03:48:07 pm » |
found a sketch for sim900,that should activate led pin output when receives an sms with on but does not,my serial monitors shows the sketch reading the sms without any problems but no led lights up.Got the gsm shield set on software serial and using uno R3,also tried using it in hardware serial mode,did not work,in hardware serial mode pin1 and 2 are (txrx),not sure how to re-configure in the sketch and not sure why led is not high when sms with ,on is sent.
[code]#define _SS_MAX_RX_BUFF 128 // RX buffer size #include <SoftwareSerial.h> SoftwareSerial mySerial(7, 8);
// EN: String buffer for the GPRS shield message // FR: Mémoire tampon de type string pour les messages du shield GPRS String msg = String(""); // EN: Set to 1 when the next GPRS shield message will contains the SMS message // FR: Est mis à 1 quand le prochain message du shield GPRS contiendra le contenu du SMS int SmsContentFlag = 0;
// EN: Pin of the LED to turn ON and OFF depending on the received message // FR: Pin de la LED a allumer/éteindre en fonction du message reçu int ledPin = 13;
// EN: Code PIN of the SIM card (if applied) // FR: Code PIN de la carte SIM (si applicable) String SIM_PIN_CODE = String( "XXXX" ); void setup() { mySerial.begin(19200); // the GPRS baud rate Serial.begin(19200); // the GPRS baud rate
// Initialize la PIN pinMode( ledPin, OUTPUT ); digitalWrite( ledPin, LOW ); } void loop() { char SerialInByte; if(Serial.available()) { mySerial.print((unsigned char)Serial.read()); } else if(mySerial.available()) { char SerialInByte; SerialInByte = (unsigned char)mySerial.read(); // EN: Relay to Arduino IDE Monitor // FR: Relayer l'information vers le moniteur Serie Arduino Serial.print( SerialInByte ); // ------------------------------------------------------------------- // EN: Program also listen to the GPRS shield message. // FR: Le programme écoute également les messages issus du GPRS Shield. // ------------------------------------------------------------------- // EN: If the message ends with <CR> then process the message // FR: Si le message se termine par un <CR> alors traiter le message if( SerialInByte == 13 ){ // EN: Store the char into the message buffer // FR: Stocké le caractère dans le buffer de message ProcessGprsMsg(); } if( SerialInByte == 10 ){ // EN: Skip Line feed // FR: Ignorer les Line Feed } else { // EN: store the current character in the message string buffer // FR: stocker le caractère dans la mémoire tampon réservé au message msg += String(SerialInByte); } } }
// EN: Make action based on the content of the SMS. // Notice than SMS content is the result of the processing of several GPRS shield messages. // FR: Execute une action sur base du contenu d'un SMS. // Notez que le contenu du SMS est le résultat du traitement de plusieurs messages du shield GPRS. void ProcessSms( String sms ){ Serial.print( "ProcessSms for [" ); Serial.print( sms ); Serial.println( "]" ); if( sms.indexOf("on") >= 0 ){ digitalWrite( ledPin, HIGH ); Serial.println( "LED IS ON" ); return; } if( sms.indexOf("off") >= 0 ){ digitalWrite( ledPin, LOW ); Serial.println( "LED IS OFF" ); return; } }
// EN: Send the SIM PIN Code to the GPRS shield // FR: Envoyer le code PIN de la carte SIM au shield GRPS void GprsSendPinCode(){ if( SIM_PIN_CODE.indexOf("XXXX")>=0 ){ Serial.println( "*** OUPS! you did not have provided a PIN CODE for your SIM CARD. ***" ); Serial.println( "*** Please, define the SIM_PIN_CODE variable . ***" ); return; } mySerial.print("AT+CPIN="); mySerial.println( SIM_PIN_CODE ); }
// EN: Request Text Mode for SMS messaging // FR: Demande d'utiliser le mode Text pour la gestion des messages void GprsTextModeSMS(){ mySerial.println( "AT+CMGF=1" ); }
void GprsReadSmsStore( String SmsStorePos ){ // Serial.print( "GprsReadSmsStore for storePos " ); // Serial.println( SmsStorePos ); mySerial.print( "AT+CMGR=" ); mySerial.println( SmsStorePos ); }
// EN: Clear the GPRS shield message buffer // FR: efface le contenu de la mémoire tampon des messages du GPRS shield. void ClearGprsMsg(){ msg = ""; }
// EN: interpret the GPRS shield message and act appropiately // FR: interprete le message du GPRS shield et agit en conséquence void ProcessGprsMsg() { Serial.println(""); Serial.print( "GPRS Message: [" ); Serial.print( msg ); Serial.println( "]" );
/*The following code used only when you have set pin code to your SIM card*/ // if( msg.indexOf( "+CPIN: SIM PIN" ) >= 0 ){ // Serial.println( "*** NEED FOR SIM PIN CODE ***" ); // Serial.println( "PIN CODE *** WILL BE SEND NOW" ); // GprsSendPinCode(); // }
if( msg.indexOf( "Call Ready" ) >= 0 ){ Serial.println( "*** GPRS Shield registered on Mobile Network ***" ); GprsTextModeSMS(); } // EN: unsolicited message received when getting a SMS message // FR: Message non sollicité quand un SMS arrive if( msg.indexOf( "+CMTI" ) >= 0 ){ Serial.println( "*** SMS Received ***" ); // EN: Look for the coma in the full message (+CMTI: "SM",6) // In the sample, the SMS is stored at position 6 // FR: Rechercher la position de la virgule dans le message complet (+CMTI: "SM",6) // Dans l'exemple, le SMS est stocké à la position 6 int iPos = msg.indexOf( "," ); String SmsStorePos = msg.substring( iPos+1 ); Serial.print( "SMS stored at " ); Serial.println( SmsStorePos ); // EN: Ask to read the SMS store // FR: Demande de lecture du stockage SMS GprsReadSmsStore( SmsStorePos ); } // EN: SMS store readed through UART (result of GprsReadSmsStore request) // FR: Lecture du stockage SMS via l'UART (résultat de la requete GprsReadSmsStore) if( msg.indexOf( "+CMGR:" ) >= 0 ){ // EN: Next message will contains the BODY of SMS // FR: Le prochain message contiendra le contenu du SMS SmsContentFlag = 1; // EN: Following lines are essentiel to not clear the flag! // FR: Les ligne suivantes sont essentielle pour ne pas effacer le flag! ClearGprsMsg(); return; } // EN: +CMGR message just before indicate that the following GRPS Shield message // (this message) will contains the SMS body // FR: le message +CMGR précédent indiquait que le message suivant du Shield GPRS // (ce message) contient le corps du SMS if( SmsContentFlag == 1 ){ Serial.println( "*** SMS MESSAGE CONTENT ***" ); Serial.println( msg ); Serial.println( "*** END OF SMS MESSAGE ***" ); ProcessSms( msg ); } ClearGprsMsg(); // EN: Always clear the flag // FR: Toujours mettre le flag à 0 SmsContentFlag = 0; } GPRS Message: [0Àÿÿÿÿÿÿÿÿ]
RDY
GPRS Message: [ RDY]
GPRS Message: [ ]
+CFUN: 1
GPRS Message: [ +CFUN: 1]
GPRS Message: [ ]
+CPIN: READY
GPRS Message: [ +CPIN: READY]
GPRS Message: [ ]
Call Ready
GPRS Message: [ Call Ready] *** GPRS Shield registered on Mobile Network ***
AT+CMGF=1
GPRS Message: [ AT+CMGF=1]
GPRS Message: [ ]
OK
GPRS Message: [ OK]
GPRS Message: [ ]
+CMTI: "SM",1
GPRS Message: [ +CMTI: "SM",1] *** SMS Received *** SMS stored at 1
AT+CMGR=1
GPRS Message: [ AT+CMGR=1]
GPRS Message: [ ]
+CMGR: "REC UNREAD","+27764569***","","13/01/11,22:24:02+08"
GPRS Message: [ +CMGR: "REC UNREAD","+27764569***","","13/01/11,22:24:02+08"]
GPRS Message: [ ] *** SMS MESSAGE CONTENT ***
*** END OF SMS MESSAGE *** ProcessSms for [ ]
OK
GPRS Message: [ OK]
GPRS Message: [ ]
+CMTI: "SM",2
GPRS Message: [ +CMTI: "SM",2] *** SMS Received *** SMS stored at 2
AT+CMGR=2
GPRS Message: [ AT+CMGR=2]
GPRS Message: [ ]
+CMGR: "REC UNREAD","+27764569***","","13/01/11,22:04:23+08"
GPRS Message: [ +CMGR: "REC UNREAD","+27764569***","","13/01/11,22:04:23+08"]
*** END OF SMS MESSAGE *** [/code]
« Last Edit: January 11, 2013, 03:53:23 pm by kevin-se »
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #43 on: January 11, 2013, 06:09:00 pm » |
hi sir, not sure if its done correctly but there's my attempt, yes the data does get corrupted. No, it doesn't. If it did, the output would be correct before the if statement, and corrupt after. It is not correct at any point. The fact that you are trying to talk to the phone and the PC on the same serial port is the problem. found a sketch for sim900,that should activate led pin output when receives an sms with on but does not,my serial monitors shows the sketch reading the sms without any problems but no led lights up.Got the gsm shield set on software serial and using uno R3,also tried using it in hardware serial mode,did not work,in hardware serial mode pin1 and 2 are (txrx),not sure how to re-configure in the sketch and not sure why led is not high when sms with ,on is sent. Look through the output you showed. Where do you see "on" or "off" in that output?
Logged
0
Online
Tesla Member
Arduino rocks
« Reply #44 on: January 11, 2013, 07:18:36 pm » |
hi sir, not sure if its done correctly but there's my attempt, The below web code shows how to capture an incomming string and see if it contains an "on' or "off", then act appropriately. Might have something useful for you. //zoomkat 12-08-12 //get submit box code //for use with IDE 1.0 //open serial monitor to see what the arduino receives //use the \ slash to escape the " in the html or use a ' //address will look like http://192.168.1.102:84 when submited //for use with W5100 based ethernet shields //note that the below bug fix may be required // http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h> #include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address byte ip[] = { 192, 168, 1, 102 }; // ip in lan byte gateway[] = { 192, 168, 1, 1 }; // internet access via router byte subnet[] = { 255, 255, 255, 0 }; //subnet mask EthernetServer server(84);; //server port
String readString;
void setup(){
pinMode(5, OUTPUT); //pin selected to control //start Ethernet Ethernet.begin(mac, ip, gateway, subnet); server.begin();
//enable serial data print Serial.begin(9600); Serial.println("server text box test1"); // so I can keep track of what is loaded }
void loop(){ // Create a client connection EthernetClient client = server.available(); if (client) { while (client.connected()) { if (client.available()) { char c = client.read();
//read char by char HTTP request if (readString.length() < 100) {
//store characters to string readString += c; //Serial.print(c); }
//if HTTP request has ended if (c == '\n') {
/////////////// Serial.println(readString); //see what was captured
//now output HTML data header
client.println("HTTP/1.1 200 OK"); client.println("Content-Type: text/html"); client.println();
client.println("<HTML>"); client.println("<HEAD>"); client.println("<TITLE>Arduino GET test page</TITLE>"); client.println("</HEAD>"); client.println("<BODY>");
client.println("<H1>HTML form GET example</H1>");
client.println("<FORM ACTION='/' method=get >"); //uses IP/port of web page
client.println("Pin 5 'on' or 'off': <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'><BR>");
client.println("<INPUT TYPE=SUBMIT NAME='submit' VALUE='Change Pin 5!'>");
client.println("</FORM>");
client.println("<BR>");
client.println("</BODY>"); client.println("</HTML>");
delay(1); //stopping client client.stop();
///////////////////// if(readString.indexOf("on") >0)//checks for on { digitalWrite(5, HIGH); // set pin 5 high Serial.println("Led On"); } if(readString.indexOf("off") >0)//checks for off { digitalWrite(5, LOW); // set pin 5 low Serial.println("Led Off"); } //clearing string for next read readString="";
Logged
