Topic: reading sms (Read 23504 times) previous topic - next topic
kevin-se
Jan 09, 2013, 03:55 pm Last Edit: Jan 09, 2013, 05:10 pm by kevin-se Reason: 1
Hi, using arduino uno r3 and sim900 shield to receive sms's and switch on
on board L.E.D,with the sketch below,i am able to read all sms's pefectly but
i need to capture the data and activate an output,if i sms the word on to
the shield,pin13 must go high,please help complete the sketch.thank you.
*  Copyright (C) 2012 Libelium Comunicaciones Distribuidas S.L.
*  http://www.libelium.com
*  This program is free software: you can redistribute it and/or modify
*  it under the terms of the GNU General Public License as published by
*  the Free Software Foundation, either version 3 of the License, or
*  (at your option) any later version.
*  This program is distributed in the hope that it will be useful,
*  but WITHOUT ANY WARRANTY; without even the implied warranty of
*  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
*  GNU General Public License for more details.
*  You should have received a copy of the GNU General Public License
*  along with this program.  If not, see .
*  Version 0.1
*  Author: Alejandro G├íllego
int led = 13;
int onModulePin = 9;        // the pin to switch on the module (without press on button)
int timesToSend = 1;        // Numbers of SMS to send
int count = 0;
int n_sms,x,sms_start;
char data[256];
void switchModule(){
    digitalWrite(onModulePin,HIGH);
    delay(2000);
    digitalWrite(onModulePin,LOW);
void setup(){
    Serial.begin(19200);                // UART baud rate
    delay(2000);
    pinMode(led, OUTPUT);
    pinMode(onModulePin, OUTPUT);
    switchModule();                    // switches the module ON
    for (int i=0;i < 5;i++){
        delay(5000);
    Serial.println("AT+CMGF=1");         // sets the SMS mode to text
void loop(){
        Serial.println("AT+CMGL");    //Reads the first SMS
         Serial.println("AT+CMGD=1,4");
        Serial.flush();
        for (x=0;x < 255;x++){
            data[x]='\0';
        x=0;
        do{
            while(Serial.available()==0);
            data[x]=Serial.read();
            x++;
            if(data[x-1]==0x0D&&data[x-2]=='"'){
                x=0;
        }while(!(data[x-1]=='K'&&data[x-2]=='O'));
        data[x-3]='\0';        //finish the string before the OK
        Serial.println(data);    //shows the message
        delay(5000);
PaulS
        Serial.flush();
Why?
I'm pretty sure that your code does not look like that. Modify your post. Select the code, delete it. Select the # icon, and re-paste your code. Save the change.
PaulS
Which version of the IDE are you using?
If you are using 1.0 or later, Serial.flush() blocks until the last character from the send buffer has been grabbed for sending. Is that really useful or necessary in your application?
Are you talking to the phone on the serial port, or the Serial Monitor? You seem to be trying to do both.
Does it? What does the message look like?
Parsing the message, if you've collected it correctly, is pretty easy. But, it would help if we saw what the message was.
PaulS
what i really want to achieve is
to switch on the on board led when i sms the word 'on' to the shield and
off to turn the led off ,in stand alone mode
What does "in stand alone mode" mean?
Use strcmp() to see if data and "on" are equal. If so, turn the LED on.
Use strcmp() to see if data and "off" are equal. If so, turn the LED off.
PeterH
You may not have realized the significance of this comment from PaulS.
You can only have one device at each end of the serial link. Your sketch is using the Arduino's hardware serial port to talk to the GSM shield. You must not connect anything else to the same serial port. The USB/Serial connection to the host PC uses the same serial port so you must not connect the USB lead at the same time as the shield is connected; that would result in both sources trying to drive the same serial Tx/Rx lines which is a bad idea.
PaulS
i am still trying to figure out how the Strcmp string works and how i would use it
if(strcmp(data, "on") == 0)
   // Turn the pin on
if(strcmp(data, "off") == 0)
   // Turn the pin off
PaulS
do i need any new variables on the top,sorry,little knowledge of c++
Not for that code.
PaulS
  digitalWrite(led,HIGH);
   digitalWrite(led,LOW); // Turn the pin off
What is up
                            with the random
        indenting? Use Tools +
   Auto Format
                 to get the code looking reasonable.
Why is that AT command sent only when the light is to be turned off?
Why is there a 5 second delay after receiving on or off before you do it?
PaulS
You're the one with the hardware. Does it work?
PaulS
Change some of your code to look like this:
        Serial.print("data: [");
        Serial.print(data);    //shows the message
        Serial.println("]");
           Serial.println("Turning LED on");
           Serial.println("Turning LED off");
Show us the serial output.
PaulS
after adding parts to the sketch,
"I changed my code, but I'm not going to show it to you." Did I paraphrase that correctly?
PaulS
when i send sms's it works perfectly,but i have problems reading sms's and activating outputs,for some reason the loop in the sketch stops after the first check when ever i try to read the serial data,
And, yet, still no code.
PaulS
maybe my delete command wrong;
One can help with coding without understanding which AT command does what. You should have functions that send exactly one AT command. The name of the function should clearly reflect what the AT command being sent does.
If
  Serial.println("AT+CMGR");    //Reads the first SMS
reads the message, and
deletes it, then, yes, you have a problem with the delete command.
data no longer gets a value, because you no longer actually read anything. So, the fact that sending the Arduino a SMS causes nothing to happen is not really surprising.
PaulS
"OK, I made some more code changes that I'm not going to show you..." Haven't we been down this path before?
We can NOT see what you are doing.
We've hired a psychic, but he's not due to start until the 12th of never. Until then, you have to help out.
PaulS
Send a command. Wait until there is a reply. Ignore the reply. Expect, magically, the data to have been read anyway.
Can anyone else see a problem with this?
What happened to the code to actually read the reply?
