Pages: [1] 2 3 ... 5   Go Down
Author Topic: reading sms  (Read 2300 times)
South Africa
Hi, using arduino uno r3 and sim900 shield to receive sms's and switch on
on board L.E.D,with the sketch below,i am able to read all sms's pefectly but
i need to capture the data and activate an output,if i sms the word on to
the shield,pin13 must go high,please help complete the sketch.thank you.
*  Copyright (C) 2012 Libelium Comunicaciones Distribuidas S.L.
*  http://www.libelium.com
*  This program is free software: you can redistribute it and/or modify
*  it under the terms of the GNU General Public License as published by
*  the Free Software Foundation, either version 3 of the License, or
*  (at your option) any later version.
*  This program is distributed in the hope that it will be useful,
*  but WITHOUT ANY WARRANTY; without even the implied warranty of
*  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
*  GNU General Public License for more details.
*  You should have received a copy of the GNU General Public License
*  along with this program.  If not, see .
*  Version 0.1
*  Author: Alejandro Gállego
int led = 13;
int onModulePin = 9;        // the pin to switch on the module (without press on button)
int timesToSend = 1;        // Numbers of SMS to send
int count = 0;
int n_sms,x,sms_start;
char data[256];
void switchModule(){
    digitalWrite(onModulePin,HIGH);
    delay(2000);
    digitalWrite(onModulePin,LOW);
void setup(){
    Serial.begin(19200);                // UART baud rate
    delay(2000);
    pinMode(led, OUTPUT);
    pinMode(onModulePin, OUTPUT);
    switchModule();                    // switches the module ON
    for (int i=0;i < 5;i++){
        delay(5000);
    Serial.println("AT+CMGF=1");         // sets the SMS mode to text
void loop(){
        Serial.println("AT+CMGL");    //Reads the first SMS
         Serial.println("AT+CMGD=1,4");
        Serial.flush();
        for (x=0;x < 255;x++){
            data[x]='\0';
        x=0;
        do{
            while(Serial.available()==0);
            data[x]=Serial.read();
            x++;
            if(data[x-1]==0x0D&&data[x-2]=='"'){
                x=0;
        }while(!(data[x-1]=='K'&&data[x-2]=='O'));
        data[x-3]='\0';        //finish the string before the OK
        Serial.println(data);    //shows the message
        delay(5000);
« Last Edit: January 09, 2013, 11:10:15 am by kevin-se » Logged
Seattle, WA USA
Seattle, WA USA
        Serial.flush();
Why?
I'm pretty sure that your code does not look like that. Modify your post. Select the code, delete it. Select the # icon, and re-paste your code. Save the change.
South Africa
The sketch seems to be reading sms's and displaying them perfectly,so i didnt want to modify it in any way,not sure about Serial.flush
Seattle, WA USA
Seattle, WA USA
Which version of the IDE are you using?
If you are using 1.0 or later, Serial.flush() blocks until the last character from the send buffer has been grabbed for sending. Is that really useful or necessary in your application?
Are you talking to the phone on the serial port, or the Serial Monitor? You seem to be trying to do both.
Does it? What does the message look like?
Parsing the message, if you've collected it correctly, is pretty easy. But, it would help if we saw what the message was.
South Africa
i view all sms's using serial monitor, in my serial monitor it shows the
contents of the sms received by the shield,when i sms on, the word on
shows up on the serial monitor,what i really want to achieve is
to switch on the on board led when i sms the word 'on' to the shield and
off to turn the led off ,in stand alone mode
Seattle, WA USA
Seattle, WA USA
What does "in stand alone mode" mean?
Use strcmp() to see if data and "on" are equal. If so, turn the LED on.
Use strcmp() to see if data and "off" are equal. If so, turn the LED off.
South Africa
sorry for the different use of english,(South Africa),i am using uno R3 and sim900 shield,using this project for switching an appliance by sms,also a beginner in
programming,
South Africa
Will have do sum research on  using the Use strcmp commands,thanks
UK
You may not have realized the significance of this comment from PaulS.
You can only have one device at each end of the serial link. Your sketch is using the Arduino's hardware serial port to talk to the GSM shield. You must not connect anything else to the same serial port. The USB/Serial connection to the host PC uses the same serial port so you must not connect the USB lead at the same time as the shield is connected; that would result in both sources trying to drive the same serial Tx/Rx lines which is a bad idea.
South Africa
o yes, now i realize there could be conflict when sharing the tx and rx,maybe
thats why some of my previous attempts ended in failure.thanks.
i am still trying to figure out how the Strcmp string works and how i would use it
in my application to compare sms's.
Seattle, WA USA
Seattle, WA USA
if(strcmp(data, "on") == 0)
   // Turn the pin on
if(strcmp(data, "off") == 0)
   // Turn the pin off
South Africa
do i need any new variables on the top,sorry,little knowledge of c++
Seattle, WA USA
Seattle, WA USA
Not for that code.
South Africa
ok,thanks,i will try out the new code now,
South Africa
OK,final sketch,please let me know if it will work,
int led = 13;
int count = 0;
char data[256];
    delay(2000);
void setup(){
    delay(2000);
        delay(5000);
void loop(){
        Serial.println("AT+CMGR");    //Reads the first SMS
        Serial.flush();
            data[x]='\0';
        x=0;
        do{
            x++;
                x=0;
        delay(5000);
  digitalWrite(led,HIGH);
   digitalWrite(led,LOW); // Turn the pin off
Pages: [1] 2 3 ... 5   Go Up
