Pages: 1 [2] 3 4 5   Go Down
Author Topic: reading sms  (Read 2309 times)
Seattle, WA USA
Seattle, WA USA
    if(strcmp(data, "on") == 0)
  digitalWrite(led,HIGH);
if(strcmp(data, "off") == 0)
   digitalWrite(led,LOW); // Turn the pin off
    Serial.println("AT+CMGD=1,4");
What is up
                            with the random
        indenting? Use Tools +
   Auto Format
                 to get the code looking reasonable.
Why is that AT command sent only when the light is to be turned off?
Why is there a 5 second delay after receiving on or off before you do it?
South Africa
sorry,i was a bit excited ,
int led = 13;
int onModulePin = 9;        // the pin to switch on the module (without press on button)
int timesToSend = 1;        // Numbers of SMS to send
int count = 0;
int n_sms,x,sms_start;
char data[256];
void switchModule(){
    digitalWrite(onModulePin,HIGH);
    delay(2000);
    digitalWrite(onModulePin,LOW);
void setup(){
    Serial.begin(19200);                // UART baud rate
    delay(2000);
    pinMode(led, OUTPUT);
    pinMode(onModulePin, OUTPUT);
    switchModule();                    // switches the module ON
    for (int i=0;i < 5;i++){
        delay(5000);
    Serial.println("AT+CMGF=1");         // sets the SMS mode to text
void loop(){
        Serial.println("AT+CMGR");    //Reads the first SMS
        Serial.flush();
        for (x=0;x < 255;x++){
            data[x]='\0';
        x=0;
        do{
            while(Serial.available()==0);
            data[x]=Serial.read();
            x++;
            if(data[x-1]==0x0D&&data[x-2]=='"'){
                x=0;
        }while(!(data[x-1]=='K'&&data[x-2]=='O'));
        data[x-3]='\0';        //finish the string before the OK
        Serial.println(data);    //shows the message
Seattle, WA USA
Seattle, WA USA
You're the one with the hardware. Does it work?
South Africa
not working ,sent sms on to shield,led pin 13 on uno  does not light ,
Seattle, WA USA
Seattle, WA USA
Change some of your code to look like this:
        Serial.print("data: [");
        Serial.print(data);    //shows the message
        Serial.println("]");
           Serial.println("Turning LED on");
           Serial.println("Turning LED off");
Show us the serial output.
South Africa
not working,on the serial monitor AT commands seems to stop after the
first check
AT+CMGF=1
AT+CMGR
AT+CMGD=1,4
Stops after ist check,before kept on checking
int led = 13;
int count = 0;
char data[256];
  delay(2000);
void setup(){
  delay(2000);
    delay(5000);
void loop(){
  Serial.flush();
    data[x]='\0';
  x=0;
  do{
    x++;
      x=0;
South Africa
after adding parts to the sketch,the serial output looks like this,
with the original sketch it used to continuously check but now it seems
to stop after a few checks,
+CFUN: 1
+CPIN: READY
Call Ready
AT+CMGF=1
AT+CMGL
AT+CMGD=1,4
AT+CMGL
AT+CMGD=1,4
AT+CMGL
AT+CMGD=1,4
Seattle, WA USA
Seattle, WA USA
"I changed my code, but I'm not going to show it to you." Did I paraphrase that correctly?
South Africa
when i send sms's it works perfectly,but i have problems reading sms's and activating outputs,for some reason the loop in the sketch stops after the first check when ever i try to read the serial data,
Seattle, WA USA
Seattle, WA USA
And, yet, still no code.
South Africa
after hours of trying,i deleted some code and ended up with this,it seems to continuously check for new sms's but when i send the shield an sms it does not show up on the serial monitor and does not switch led on,maybe my delete command wrong;
int led = 13;
int count = 0;
char data[256];
  delay(2000);
void setup(){
  delay(2000);
  delay(5000);
void loop(){
Seattle, WA USA
Seattle, WA USA
One can help with coding without understanding which AT command does what. You should have functions that send exactly one AT command. The name of the function should clearly reflect what the AT command being sent does.
If
reads the message, and
deletes it, then, yes, you have a problem with the delete command.
data no longer gets a value, because you no longer actually read anything. So, the fact that sending the Arduino a SMS causes nothing to happen is not really surprising.
South Africa
ok will modify
South Africa
ok,left out the AT command for deleting sms's,the AT+CMGR=1 reads incoming sms's but nothings displayed on the serial monitor and no switching occurs,the AT+CMGR command keeps looping on serial monitor but not reading the new sms's
Seattle, WA USA
Seattle, WA USA
"OK, I made some more code changes that I'm not going to show you..." Haven't we been down this path before?
We can NOT see what you are doing.
We've hired a psychic, but he's not due to start until the 12th of never. Until then, you have to help out.
Pages: 1 [2] 3 4 5   Go Up
