Topic: R: Road to solve the delay on the Arduino IDE (Read 10544 times) previous topic - next topic
federicofissore
Jan 09, 2013, 06:36 pm Last Edit: Jan 15, 2013, 12:20 pm by federicofissore Reason: 1
The old original topic was http://arduino.cc/forum/index.php/topic,46977.0.html
Thanks to eried, to neophob (http://neophob.com/2011/05/serial-library-rxtx-v2-2pre5/) and to the guys and girls working on RXTX (the piece of software we use to make the pc communicate with our boards) I've managed to fix the "tools" menu delay issue.
I need someone volunteering and testing the fix. Instructions below:
Attached you can find a .zip which contains 2 files. You have to overwrite the existing ones with the ones attached. BEFORE you do so, back them up: copy them somewhere else, so you can restore them if bad things happen.
One file is "RXTXComm.jar": it is a multiplatform file, everyone of you has it under folder "lib" in the folder where you have installed your arduino ide.
The other file is specific to your operating system: I've managed to make the linux 32 and 64 bit and windows versions. Mac versions will soon follow.
If you have a 32bit or 64bit linux, copy file librxtxSerial.so from folder linux32 or linux64 into folder "lib" (right next RXTXComm.jar)
If you have windows, copy file windows/rxtxSerial.dll into the folder where you have installed your arduino ide (right next arduino.exe)
Run the ide and report back: is everything running as usual? If you were experiencing the tools menu delay: has it disappeared?
Thank you in advance
Federico
federicofissore
I've updated the zip file to include the mac specific lib: it's only for Intel based macs
Darkblade48
The IDE seems to be running as usual after replacing the JAR file as well as the DLL, but the delay in the tool menu still seems to persist.
federicofissore
Have you tried latest IDE release? (1.5.4)
Rob Cameron
Speaking of an updated IDE, I just opened a ticket over the GitHub repo with a new proposed design and some missing features:
https://github.com/arduino/Arduino/issues/1590
Rob
bd85
I'm running OSX and recently upgraded my IDE from 1.0.5 to 1.5.7 to use the Yun and am experiencing the delay issues both on startup and when selecting the Tools menu.  I also tried older 1.5.x builds and had the same issue.  I don't have any problems using 1.0.5 and an Uno.
I attempted to follow the instructions but haven't been able to figure out where to place the updated files.  They don't appear to already exist in the lib folder when I look through the Arduino package in OSX.  I searched my computer and couldn't find a file with RXTX other than the ones I downloaded using the links from this thread.  As an alternative I tried to place the files in the Extensions folder in HD/Library/Java/Extensions but to no avail.  I also tried turning off Bluetooth which had been suggested in other threads.
Any suggestions would be greatly appreciated.
westfw
I thought that the original issue was window only, and is old.
A "delay" problem with Yun on Mac is probably a new and different problem; try starting a new thread.
coolfire
I purposely sign-up, just to say thanks Federico Fissore :)
I followed the steps exactly, and it resolved my 'Tool' menu lagging problem.
jjones11
Why is this still a problem after 5 years?  I'm on a Win7-Pro 64-bit PC.  Yesterday, I downloaded and installed the latest and greatest Arduino (1.0.6) and immediately smacked into the "Tools Menu Delay" issue.
Googling reveals this has been an issue since 2009, and apparently with every release of Arduino since!  Tracking down and using the custom-built rxtxSerial.dll works fine (old fix - haven't yet tried Frederico's fix yet), but it's very disappointing that this has not been fixed by the powers-that-be years ago.  Is this the normal mode of operation with Arduino?
It's a pretty cool package regardless... thanks to you users out there, and this forum.
westfw
Quote
If that's a serious question, the answer is PROBABLY that rxtxserial is an imported component where the arduino team doesn't want to modify or support their own version, and the people who do maintain it didn't hear about the problem, haven't fixed it yet, or have chosen not to fix it.
smitex2
Thanks very much, works for me to, i'm using windows 8.1 on a hp netbook
bobcousins
Sadly yes. :(
And it can't be said that it is because users fail to raise issues, or that devs are unwilling to commit changes and help improve Arduino, because there are hundreds of outstanding issues on github, and dozens of fixes and pull requests which never get incorporated.
Please ask questions in the forum so everyone can benefit. PM me for paid work.
ondronr
rxtxSerial.dll should be replaced with JSSC as of ARDUINO 1.5.6 BETA - 2014.02.20
Quote
* Replaced RXTX library with JSSC (Alexey Sokolov)
http://code.google.com/p/java-simple-serial-connector/
https://github.com/arduino/Arduino/blob/master/build/shared/revisions.txt
