Author Topic: Digital photo convertor  (Read 152 times)
Recently I purchased a digital photo convertor that I can feed my photos and negatives to and it digitizes them and stores them on the SD card.
I was not happy with the quality and compression of the resultant images though.
I think I have necessary expertise to build something like this on my own using a stepper motors and line scanners (both of which I plan to salvage from an old scanner) with my trusty Arduino Uno.
Before starting on this though, I want to check if anyone else has attempted something like this and maybe can share the details and pitfalls faced.
Thanks.
UK
Online Online
What do you plan on using for the image processing?
bitmap for now. The main components in this is to use stepper motor to advance photo/negative at constant rate and use line scanner to scan each line.
Austin, TX
CMiYC
The Arduino can move steppers just fine. I think AWOL was getting at, what will you do with the image data itself. There Arduino can't do much with that.
www.cmiyc.com - A guide to being an Enginerd
Poole, Dorset, UK
Which "photo converter" do you have. I don't think you will beat it with bits from an old scanner.
Mark
James C4S,
I'd leave image processing to higher powers (in 32-bit land). Arduino based board will be to capture and save/send.
holmes4,
scavenged parts are just for proof-of-concept. Once successful, I'd go with a CCD or CMOS. I'll need to do more research on this though.
Austin, TX
CMiYC
With 2K of SRAM, this contraption won't be setting any speed records.
UK
It would be a fun project, but matching let alone beating the scanning quality of a modern scanner with a DIY solution seems very optimistic to me.
What sort of resolution and quality are you aiming to achieve, and for what sort of scan size?
UK
Online Online
..and a slow, low resolution ADC isn't going to help.
Imagine a fairly low resolution scan of 1024 x 1024 pixels.
So, 1024 x 1024 x 3 (RGB) pixels at around 9500 samples per second is around five and a half minutes.
