Topic: Sending Float values to Pachube from Arduino (Read 6942 times) previous topic - next topic
terryking228
Hi Everyone,
I have a Duemilanove type board with a W5100 Ethernet Shield. I am reading data from a DHT11 Temperature-Humidity sensor. Running 1.02 IDE.
I have it successfully sending integer data to https://cosm.com/feeds/96820
BUT I really want to be sending floating point data.
Does anyone have a working example of doing this??
I have looked through lots of stuff about using separate Float-to-String code, using a C++ library, and advice that says "Don't Use Strings, even if they are in the Arduino IDE distribution"..
I THOUGHT "It can't be that hard!".. but after 4 or 5 hours of floundering and crashing I'd like your advice!
Thanks!
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
HazardsMind
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
robtillaart
The DHT11 does not return a FP type, still the question is interesting, no answer (yet)
Rob Tillaart
MichaelMeissner
#4
Jan 09, 2013, 08:28 pm Last Edit: Jan 09, 2013, 08:33 pm by MichaelMeissner Reason: 1
If you are doing binary transfer, remember that the Arduino 'double' is actually the same as 'float' on other systems, and the AVR is little endian.
From your question however, I assume you are trying to write out the value as a sequence of characters, transmit them via the network, and then the program on the other side will do scanf or similar function to convert the number back to the internal representation used on that system.  You can't use the *printf functions by default, since the AVR printf is compiled without floating point support (to save a lot of code space).  It looks like the IDE has alternate forms of printf/scanf that include the floating point support, but I don't know how to get those libraries included.
I'm at work right now, but the low level function seems to be: dtostrf:  http://www.sourcecodebrowser.com/avr-libc/1.8.0/dtostrf_8c.html
It has the following prototype:
#include <stdlib.h>
char *dtostrf(double value, signed char width, unsigned char prec, char *s);
So I imagine you call it:
const int size = 10;
const int precision = 2;
void print_num (double value)
   char buffer[size+1];
   dtostrf (value, size, precision, buffer);
   Serial.println (buffer);
You would change Serial.println to whatever you are using to transfer the number.
robtillaart
@terry
it is solved in this thread - http://community.cosm.com/node/957 -
Rob Tillaart
terryking228
Thanks for the quick responses, everyone...
Rob, you know more about DHT11/DHT22 than anyone I think.  I guess I have been looking at the examples that do Serial.print with (float) of the values. Hmmm..
They do conversions to Fahrenheit and Dew Point using  Float.
How about DHT22?? I have one and might use that also.
I am trying to write a good clear example of using Pachube to send sensor data to the web and graph it, for a workshop I'll be doing. Probably will be better after it's Clear to ME !!
Other: I also plan to use DS18B20 sensors, that will return Float data.   Rob, the pointer you gave uses DS18B20 and I need to dig into that. It uses a library that hides the details of building the HTTP PUT format characters.  Maybe that's good. I was hoping to understand the gritty details..
Michael, I tried dtostrf but backed off when it (my code anyway) crashed after one loop. Took it out and OK..  Memory Leaks? String overlays?  hard to debug. It uses a char buffer; Would I have to manually assure the data is zero/nul terminated?
HazardsMind, that's an interesting site.. not Pachube but they do send float data.
OK, back to the fray. Many thanks for the pointers and I will post back what I learn and I will be putting an example up with lots of How-To embedded.
Soon as I Know How To...
robtillaart
Too much honor, I am only standing on the shoulders of giants**
The solution seems to be in this "new" cosm lib - https://github.com/blawson/PachubeArduino -
especially the cpp file - https://github.com/blawson/PachubeArduino/blob/master/Cosm.cpp -
it uses _client.print(dataToSend, DEC);
when dataToSend is a float/double,  DEC will be interpreted as the number of decimals. // not too nice usage of DEC but OK
but most important,  OP states it works/solves his problem of posting floats to cosm.
I have not confirmed it (no duino with ethernet nearby) but I expect you will within a day or so ;)
Let us know if it works.
** originally from Sir Isaac Newton IIRC ;)
Rob Tillaart
Nick_Pyner
#8
Jan 10, 2013, 12:37 am Last Edit: Jan 10, 2013, 02:50 am by Nick_Pyner Reason: 1
Well, if the DHT11 does not deliver Floating point and in the light of the above quote, you already know what to do, and there is plenty info on that.
An earlier version of my code is in the "It worked!" section of the cosm forum, october I think
https://cosm.com/feeds/83153
terryking228
Thanks for the pointers/comments!  I'm back on it.. Zinged by two different libraries creating 'cosm.h' but finally hid the wrong one and I can compile an example.
Details at 11..  if the Old Guy can stay awake that long...
terryking228
#10
Jan 10, 2013, 03:35 am Last Edit: Jan 10, 2013, 03:45 am by terryking228 Reason: 1
Hi.. OK, I may get sleep after all :smiley-sleep:
I got it working well with the Cosm-Arduino library. (Links in the code example below). It makes it easy to change the number of variables(streams) and if they are int or float.  I have it running on https://cosm.com/feeds/96891
Tomorrow I will work on integrating DHT11 and DS18B20 sensors in an example. For now it just sends phoney changing int and float data.
Many thanks to all.. This is a community I am very happy to be part of!
OK, let's see if I know how to do the Code Thing...
OH: Please nitpick my format and comments in this code etc..  I want this to be as clear as I wished it was at 1AM last night.  Think of very inexperienced Arduino enthusiasts reading this, not BitHeads like Rob :-)  There will be a WIKI page of How-to and explanation to go with this code.
/* YourDuinoStarter Example: Web Cloud Data Display for Arduino
- Create Web Server to send data to cosm.com for display/archive
- SEE the comments after "//" on each line below
- CONNECTIONS:
- V1.03 01/09/12
  Questions: terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <SPI.h>        // Standard Arduino Library
#include <Ethernet.h>   // Standard Arduino Library
#include <HttpClient.h> // HttpClient lib : https://github.com/amcewen/HttpClient
#include <Cosm.h>       // Cosm Arduino lib : https://github.com/mnin/CosmArduino
// NOTE: The lines below are from the automatically generated Arduino code that Cosm makes
// when you create a new feed. Cut and paste just these lines for reference
// #define API_KEY "r5LAQylJnH2_S05o1t8yi1yxBtiSAKxxSmpJR0orTTVlbz0g" // your Cosm API key
// #define FEED_ID 96891 // your Cosm feed ID
// NOTE: The "API Key" and "Feed ID" are unique to you. Get them from your Cosm account.
// The API Key is located at https://cosm.com/users/<cosm_username>/keys
/*-----( Declare Constants and Pin Numbers )-----*/
char     cosmKey[]     = "r5LAQylJnH2_S05o1t8yi1yxBtiSAKxxSmpJR0orTTVlbz0g";
unsigned long  FeedID  = 96891;
/*-----( Declare Variables )-----*/
// MAC address for your Ethernet shield:Change if you have more than one on your network
IPAddress ip(192,168,1,122);   // Available Static IP address on your Network. See Instructions
// Define the strings for our datastream IDs
char sensorId[]  = "Int1";
char sensorId2[] = "Int2";
char sensorId3[] = "Float1";
char sensorId4[] = "Float2";
// Define variables for Sensor data to be sent to Cosm
int   A,B;             // Change to your sensor variable names
float C,D;             // Change to your sensor variable names
int cosmReturn = 0;    // Result Return code from data send
/*-----( Declare objects )-----*/
// NOTE:  DATASTREAM_INT = integer    DATASTREAM_FLOAT = float
// Define the 4 streams
CosmDatastream datastreams[] = {
 CosmDatastream(sensorId, strlen(sensorId), DATASTREAM_INT),    // define this ID in cosm
 CosmDatastream(sensorId2, strlen(sensorId), DATASTREAM_INT),   // define this ID in cosm
 CosmDatastream(sensorId3, strlen(sensorId), DATASTREAM_FLOAT), // define this ID in cosm
 CosmDatastream(sensorId4, strlen(sensorId), DATASTREAM_FLOAT), // define this ID in cosm
// Define the Feed, consisting of the 4 DataStreams
CosmFeed feed(FeedID, datastreams, 4 );
// Define the Ethernet Library structures
EthernetClient client;
CosmClient cosmclient(client);
/*------------------( END OF DECLARATION AREA )-----------------------------*/
void setup()   /****** SETUP: RUNS ONCE ******/
  Serial.begin(9600);  //Ready to send debug info to Serial Monitor
  Serial.println("Starting datastream upload to Cosm...");
  Serial.println("Starting Ethernet Client...");
  Ethernet.begin(mac, ip);
  Serial.println("Ethernet client & IP address OK");
// Initialize Sensor Data For Test
 A = 10;
 B = 20;
 C = 40.12;
 D = 80.24;
 delay(1000);  //Wait for Server to start up
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
 // Put your sensor input code here (This is temporary for changing data for test)
 A = A + 1;
 B = B + 2;
 C = C * 1.05;
 D = D * 1.10;
 // Put sensor values into the 4 datastreams,
 // NOTE: Use setInt() for integer   setFloat() for floating point
 datastreams[0].setInt(A);    // Set sensor values into datastreams 1
 datastreams[1].setInt(B);    // Set sensor values into datastreams 2
 datastreams[2].setFloat(C);  // Set sensor values into datastreams 3
 datastreams[3].setFloat(D);  // Set sensor values into datastreams 4
 // NOTE:  getInt for integer, getFloat for floating point
 // Show the values in the streams for test/debug
 Serial.print("A:");
 Serial.println(datastreams[0].getInt());  // Print datastream to serial monitor
 Serial.print("B:");
 Serial.println(datastreams[1].getInt());  // Print datastream to serial monitor
 Serial.print("C:");
 Serial.println(datastreams[2].getFloat());  // Print datastream to serial monitor
 Serial.print("D:");
 Serial.println(datastreams[3].getFloat());  // Print datastream to serial monitor
 // Send the feed to cosm. (while testing/debugging sensor codes, you can comment it out.
  cosmReturn = cosmclient.put(feed,cosmKey);   // Send feed to cosm
  Serial.print("COSM client returned : "); // Get return result code, similar to HTTP code
  if (cosmReturn == 200) { Serial.print(" OK "); }
  Serial.println(cosmReturn);
 delay(2000); // Put a delay before the next updates to Cosm
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
//*********( THE END )***********
Nick_Pyner
I wish I had seen this last September, it looks like quite a nice child's guide to cosm.......
robtillaart
the graphs looks quite like your heartbeat Terry ;)
Rob Tillaart
Jack Christensen
Technically, these sensors do not return float data, but scaled integers. The DS18B20 returns an integer whose LS bit is 2-4 °C (1/16 °C), so it can be considered °C times 16. The DHT22 returns an integer that is °C times ten, but it also has a non-standard way to represent negative numbers; the MS bit is an independent sign bit and the remainder of the data is an absolute value.
Of course if there is a library involved to read the sensor it could well return a float after converting the data from the sensor.
I read the DS18B20 using the OneWire.h library, which just handles the details of the communication and returns the data directly from the sensor. I use integer arithmetic to convert it to °F times ten. To send it to Cosm, I use the value/10 and value%10, along with itoa() and strcat() to build the required CSV representation including the decimal point.
Example: https://cosm.com/feeds/17534
terryking228
@Jack, You are correct in that these sensors are not natively Floating Point.  But I feel I need to be able to manipulate their result as Float, do conversions and derive new data like differentials etc.  That was the motivation for handling Float as Float.  You methods are more flexible (and probably more computationally efficient) but I am trying to support relative beginners in the Arduino world. Thanks for the perspective.
@Rob  ..Hmmm... Maybe my position on Net Neutrality will change. With about 3E9 heartbeats so far I want to maximize my number as far as possible.
