Loading...
Pages: [1]   Go Down
Author Topic: How to program an stand-alone atmega328?  (Read 232 times)
Maaseik, Belgium
Offline Offline
Newbie
View Profile
I have burned a bootloader on a atmega328 with the help of this topic. I have also a MEGA 2560. How can a program the atmega328 on an breadboard? Can I also program the AVR without a bootloader?
If I select my MEGA as an 'Arduino as ISP' and I select the board 'ATmega328 on a breadboard', I get the error message : avrdude: stk500_getsync(): not in sync: resp=0x00
This is inserted on my boards.txt:
Code:
atmega328bb.name=ATmega328 on a breadboard (8 MHz interne clock)
atmega328bb.upload.protocol=stk500
atmega328bb.upload.maximum_size=30720
atmega328bb.upload.speed=57600
atmega328bb.bootloader.low_fuses=0xE2
atmega328bb.bootloader.high_fuses=0xDA
atmega328bb.bootloader.extended_fuses=0x05
atmega328bb.bootloader.path=arduino:atmega
atmega328bb.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
atmega328bb.bootloader.unlock_bits=0x3F
atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.build.mcu=atmega328p
atmega328bb.build.f_cpu=8000000L
atmega328bb.build.core=arduino:arduino
atmega328bb.build.variant=arduino:standard
« Last Edit: January 09, 2013, 03:55:47 pm by vovpvi » Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
A search with Google for the answer to your question
Quote
"How to program an stand-alone atmega328?"
brought this answer... My don't you feel 'silly'... You typed the question where the answer goes..
If you'd just put the question in the right place, You might be capable of telling us.
On a more or less serious note Googling for the answer is much faster than asking here and either someone else did what I did which was copy your question into a search box.. Or waiting for the person with the same knowledge to read your question and answer it.
This is the primary reason for using Google to begin with, You can find all the answers in one place.
It works for Me.
http://arduino.cc/en/Tutorial/ArduinoToBreadboard
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Maaseik, Belgium
Offline Offline
Newbie
View Profile
In my start-topic you can read that I have an Arduino MEGA. So that means I cannot remove the microcontroller from the arduino board.
Logged
Pages: [1]   Go Up
Print
Jump to:
