Topic: Shift Register Library (Read 1 time) previous topic - next topic
max713
I have 4 daisy-chained shift registers. I just wanted to know if anybody knows a special library which makes programming much easier.
Thanks,
max
cmagagna
Your question is a little vague...what do you want to do with them?
There's the SPI library, you can use that to send data to shift registers faster than shiftOut().
There's the ShiftPWM library (http://www.elcojacobs.com/shiftpwm/) if you want to blink some LEDs...
max713
I want to control a matrix without using shiftout(), because that would enlarge my program wouldn't it?
guix
If you use 74HC595 shift registers, you could try this one
http://code.bildr.org/project/Shift%20Register%208-Bit%20-%2074HC595/Arduino
nickgammon
I have a page about the 595 chip:
http://www.gammon.com.au/forum/?id=11518
Here (from that page) is how to daisy-chain 4 shift registers, it hardly takes a lot of code:
Code: [Select]
  digitalWrite (LATCH, LOW);
  SPI.transfer (0xAB);
  SPI.transfer (0xCD);
  SPI.transfer (0xEF);
  SPI.transfer (0x42);
  digitalWrite (LATCH, HIGH);
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
sparkie4080
Hi Nick
I went to your site and seen some of the code for the shift registers, and thought you might be able to help me.
What is SPI in your code.
I built a 4x4x4 led cube and am trying to creat a code to test each one of the leds from an X,Y,Z access.
Then eventually randomize the pattern.
If you want I could send the code I found and converted.
Sparkie
nickgammon
