Author Topic: External POWER Source? - Maximum Voltage and Current to turn on Arduino Uno  (Read 157 times)
... Hi and Sorry if my post has already been asked, but to be more direct in a way
WHAT IS THE RANGE OF VOLTAGE AND CURRENT NEEDED TO TURN ON ARDUINO UNO.?
the recommended voltage to operate atmega328, if i'm right, is 7 - 12V.
i have an ac-dc adaptor which outputs 12V and 1000ma
the voltage is in range, but i'm not sure if the current is.
SE USA
@ssh0le
current is more than enough, the uno by itself is pretty much nothing (until you go to run if off a battery, then it seems large), the regulator on board which is converting input to 5 volts is limited to (I think 500ma)
you will notice the regulator getting warm if use you 12 volts, cause (12-5) there's 7 volts that has to go somewhere, but that is acceptable... general thinking says if you can hold your finger on it for 5 seconds or more its fine, though it might alarm you if your thinking stuff should not be toasty (it shouldn't but there's math behind how toasty is too toasty, too toasty is darn near baking cookies in this case)
« Last Edit: January 09, 2013, 11:18:54 pm by Osgeld » Logged
Melbourne, Australia
Shannon Member
Lua rocks!
Please don't cross-post. Threads merged. - moderator
