Topic: Servo and Motor Driver incompatibility (Read 956 times) previous topic - next topic
Murray_Bro
Dear Forum,
I have been using an Arduino Uno and a Critical Velocity 15 Amp Bidirectional PWM Motor Speed Controller to control a 12V 10 AMP motor. Things have been running perfectly until I added a SparkFun Large Servo to the Arduino.  Now the motor will not run in reverse.   SparkFun suggests a separate power supply for the servo or noise filtering.
I have a robust 12V power supply for the Motor Controller.  Rather not add another 5V supply for the servo.
Any suggestions on how to add the servo without throwing a wrench in to the soup?   Greatly appreciated.
Chagrin
This sounds like a code problem. Did you include the Servo library in your code? On a non-Mega Arduino that will disable PWM on pins 9 and 10.
zoomkat
Well, direct 12v to the servo may kill it, and the arduino is usually inadequate to power a servo itself. You might power the servo via a 7805 regulator chip connected to the 12v power supply.
JimboZA
As they might say on 9gag... "You make a suggestion like that on this forum and you gonna have a bad time"  8)
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
zoomkat
Not sure why. I've had a pair of web cam pan/tilt servos powered like below 24/7 since 2004 without any issues.
Murray_Bro
I believe I have cleared the code.  Sketch runs fine with servo control lead disconnected.  I did include the library in the code.
I also ran a sketch with only the servo code and that runs fine.
Murray_Bro
Could you elaborate on that please?
JimboZA
Some members are "against" regulators like that because they waste power.
In a 7805 style regulator, the input current is always the same as the output current, so since it's at a higher voltage, the difference in input - output voltage, times the current, is the wasted power in watts.
That waste manifests as heat.....
Murray_Bro
Thank you JimboZA.  Would you agree that it is a power problem and not a noise problem ?  Do you have a alternate recommendation from the 7805 regulator?
Thanks again for your assistance.
