Loading...
Pages: [1] 2   Go Down
Author Topic: Windows 7 and driver signing  (Read 1100 times)
Cornwall, UK
Offline Offline
Newbie
View Profile
WWW
Hi all,
I am starting to lose the plot on this one.  I've got an Uno R3 and a Mega 2560 R3, and both are exhibiting the same problem: I cannot get Windows 7 (64 bit) to install the drivers. I know that the Arduinos are OK because I can access them using a Linux VM on the same Windows 7 machine, but the Windows machine itself won't connect to them.
I've tried all of the tips I can find online, I've turned off driver signing, everything I can think of, and it just will not work. The Arduino will be communicating with a .NET program on the PC, so I really need to get it working!
Any suggestions gratefully received while I still have some hair left!  TIA.
Logged
Germany
Offline Offline
Full Member
View Profile
look in device manager and search for the Arduino, this should be a question mark - unknown device
right click -> install driver manually.
worked for me on windows 8, 64bit
Logged
using Arduino Uno Rev 3
Cornwall, UK
Offline Offline
Newbie
View Profile
WWW
Thanks for the suggestion, but I've manually re-installed the drivers many times without success. It gets right through the install procedure, asks if I want to install an unsigned driver, I click OK, then when it completes it brings up a message saying that it couldn't install the driver because it wasn't signed.
Logged
Germany
Offline Offline
Full Member
View Profile
Try this
http://www.techspot.com/community/topics/how-to-install-use-unsigned-drivers-in-windows-vista-7-x64.127187/
solution #2
if this doesn't work, I think I cannot help you, sorry.
Logged
Chile
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
solution #3
Try: http://arduino.cc/forum/index.php/topic,118440.0.html smiley-grin it's automated, so if it still does not work, there is something bad with the system files / board
Logged
My homepage/blog: http://erwin.ried.cl
Cornwall, UK
Offline Offline
Newbie
View Profile
WWW
Thanks eried and karlok. I've tried installing the enhanced IDE (solution 3) but it still says that there is a problem with installing the drivers because they are unsigned.
I admit I'm a bit reluctant to try 2 because the driver is a built-in Windows USB driver and I don't want to risk messing up my work PC!
Logged
Cornwall, UK
Offline Offline
Newbie
View Profile
WWW
OK, I can now get the driver to install if I disable Driver Signing Enforcement on boot-up smiley but it's broken again if I reboot normally.
Is there a way of making that driver install permanent? I don't want to have to press F8 and get into the boot menu every time I start Windows.
Logged
Chile
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
That's weird, win 7 x64 should allow unsigned drivers with a warning. Can you try to find a setting for that behavior? like "allow unsigned drivers" but not that boot option, something in the control panel/PC properties.
My installer does not messes with anything, I don't like that too, the only thing I modify is the program files directory + PATH (but it is cleaned upon uninstallation)
Logged
Cornwall, UK
Offline Offline
Newbie
View Profile
WWW
That setting is not there by default in Windows 7 64-bit, I had to go into Windows\inf\sceregvl.inf and add stuff to enable it, but that doesn't make any difference.  I am currently trying to change the group policy to ignore unsigned driver errors.
Logged
Chile
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
When I had win7 x64, if I allowed unsigned drivers I got this dialog: http://usbdm.sourceforge.net/USBDM_V4.9/USBDM_JMxx/html/UpdateDriverSoftware3.png so the option is somewhere in the Control panel. In win8 there is no option so I can't say where it is, maybe in the action center? or type  "unsigned" in the search
Logged
Cornwall, UK
Offline Offline
Newbie
View Profile
WWW
I get that dialog too, and I click on "Install anyway", but when it gets to the end of the install it comes up with  a box saying that it failed to install because the driver wasn't signed!
It's all very strange...
Logged
Offline Offline
Jr. Member
View Profile
I think they should do a sticky on this.
Logged
Austin, TX
Offline Offline
Sr. Member
carpe diem
View Profile
Is there something unique about this Windows 7 install that you haven't mentioned?
Is this a "corporate" image or something like that, with a group policy set to restrict unsigned drivers?
A standard install of Win7 x64 does not have this issue, other than the warning during the first install.
I use it on Win7 x64 all the time without the problem you describe.
The problem you describe, seems to indicate there is a policy setting that is enforcing this behavior.
Logged
LONDON UK
Offline Offline
Full Member
View Profile
i have had this when not signed in as administrator ,i guess you tried that?
Logged
Cornwall, UK
Offline Offline
Newbie
View Profile
WWW
It doesn't work as administrator, and I'm using a standard Windows 7 install.
Could removing SP1 from Windows 7 be the cause of the problem? I had to take it off as it broke ADO compatibility with desktop programs I develop.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
