Cornwall, UK
« on: January 10, 2013, 06:24:01 am » |
Hi all,
I am starting to lose the plot on this one. I've got an Uno R3 and a Mega 2560 R3, and both are exhibiting the same problem: I cannot get Windows 7 (64 bit) to install the drivers. I know that the Arduinos are OK because I can access them using a Linux VM on the same Windows 7 machine, but the Windows machine itself won't connect to them.
I've tried all of the tips I can find online, I've turned off driver signing, everything I can think of, and it just will not work. The Arduino will be communicating with a .NET program on the PC, so I really need to get it working!
Any suggestions gratefully received while I still have some hair left! TIA.
Germany
« Reply #1 on: January 10, 2013, 10:16:10 am » |
look in device manager and search for the Arduino, this should be a question mark - unknown device right click -> install driver manually.
worked for me on windows 8, 64bit
using Arduino Uno Rev 3
Cornwall, UK
« Reply #2 on: January 10, 2013, 10:39:01 am » |
Thanks for the suggestion, but I've manually re-installed the drivers many times without success. It gets right through the install procedure, asks if I want to install an unsigned driver, I click OK, then when it completes it brings up a message saying that it couldn't install the driver because it wasn't signed.
Germany
« Reply #3 on: January 10, 2013, 12:35:49 pm » |
Chile
« Reply #4 on: January 10, 2013, 12:41:14 pm » |
solution #3 Try: http://arduino.cc/forum/index.php/topic,118440.0.html  it's automated, so if it still does not work, there is something bad with the system files / board
Cornwall, UK
« Reply #5 on: January 11, 2013, 03:57:59 am » |
Thanks eried and karlok. I've tried installing the enhanced IDE (solution 3) but it still says that there is a problem with installing the drivers because they are unsigned.
I admit I'm a bit reluctant to try 2 because the driver is a built-in Windows USB driver and I don't want to risk messing up my work PC!
Cornwall, UK
« Reply #6 on: January 11, 2013, 04:39:12 am » |
OK, I can now get the driver to install if I disable Driver Signing Enforcement on boot-up  but it's broken again if I reboot normally. Is there a way of making that driver install permanent? I don't want to have to press F8 and get into the boot menu every time I start Windows.
Chile
« Reply #7 on: January 11, 2013, 09:43:03 am » |
That's weird, win 7 x64 should allow unsigned drivers with a warning. Can you try to find a setting for that behavior? like "allow unsigned drivers" but not that boot option, something in the control panel/PC properties.
My installer does not messes with anything, I don't like that too, the only thing I modify is the program files directory + PATH (but it is cleaned upon uninstallation)
Cornwall, UK
« Reply #8 on: January 11, 2013, 10:52:17 am » |
That setting is not there by default in Windows 7 64-bit, I had to go into Windows\inf\sceregvl.inf and add stuff to enable it, but that doesn't make any difference. I am currently trying to change the group policy to ignore unsigned driver errors.
Chile
« Reply #9 on: January 11, 2013, 11:11:36 am » |
When I had win7 x64, if I allowed unsigned drivers I got this dialog: http://usbdm.sourceforge.net/USBDM_V4.9/USBDM_JMxx/html/UpdateDriverSoftware3.png so the option is somewhere in the Control panel. In win8 there is no option so I can't say where it is, maybe in the action center? or type "unsigned" in the search
Cornwall, UK
« Reply #10 on: January 11, 2013, 11:37:51 am » |
I get that dialog too, and I click on "Install anyway", but when it gets to the end of the install it comes up with a box saying that it failed to install because the driver wasn't signed!
It's all very strange...
« Reply #11 on: January 11, 2013, 06:50:14 pm » |
I think they should do a sticky on this.
Austin, TX
carpe diem
« Reply #12 on: January 12, 2013, 12:39:47 pm » |
Is there something unique about this Windows 7 install that you haven't mentioned? Is this a "corporate" image or something like that, with a group policy set to restrict unsigned drivers?
A standard install of Win7 x64 does not have this issue, other than the warning during the first install. I use it on Win7 x64 all the time without the problem you describe.
The problem you describe, seems to indicate there is a policy setting that is enforcing this behavior.
LONDON UK
« Reply #13 on: January 12, 2013, 05:11:51 pm » |
i have had this when not signed in as administrator ,i guess you tried that?
Cornwall, UK
« Reply #14 on: January 14, 2013, 05:37:21 am » |
It doesn't work as administrator, and I'm using a standard Windows 7 install.
Could removing SP1 from Windows 7 be the cause of the problem? I had to take it off as it broke ADO compatibility with desktop programs I develop.
