Topic: SPI communication on arduino uno (Read 2826 times) previous topic - next topic
Nauman048
Jan 10, 2013, 12:35 pm Last Edit: Jan 10, 2013, 07:58 pm by Coding Badly Reason: 1
Hi all
I am trying to communicate using SPI protocol between two arduino uno boards. I have writthen a very simple code to transfer a single character from master. The code is as following
#include <SPI.h>
#include "pins_arduino.h"
void setup (void)
void loop (void)
  digitalWrite(SS, HIGH);  // ensure SS stays high
  SPI.begin ();
  delay (5000);  // 5 seconds delay to start logic analyser.
  // enable Slave Select
  digitalWrite(SS, LOW);    // SS is pin 10
  // send test string
    SPI.transfer ( 'c');
// disable Slave Select
// turn SPI hardware off
SPI.end ();
while (1);  //loop
Please correct the code if its not right. And I really want to know that how to recieve that character on arduino uno in slave mode. There is a command SPI.transfer() to send data on SPI where as I haven't seen any command to recieve it.
Thanks and regards
Moderator edit: [code] [/code] tags added.
cmagagna
Nick Gammon has an excellent writeup on SPI, including master/slave data exchange, at:
http://www.gammon.com.au/forum/?id=10892
Good luck!
Coding Badly
You cross-post one more time and I will ban you.
Nauman048
Thanks magagna...
One thing is clear to me that when using the command of SPI.transfer() both the MOSI and MISO are clocked out and in respectively. Now the question is how to grab the bit coming on MISO if my arduino is Master.
cmagagna
On Nick Gammon's page see the section "how to get a response from a slave". Specifically the code line
byte a = SPI.transfer (what);
On the master you call SPI.transfer() to send a byte to the slave, and the function returns the byte coming from the slave.
Nauman048
Thanks magagna...
I have learnt how to communicate bi-directionally...
Regards
