FROSINONE (FR)
« on: January 10, 2013, 08:46:37 am » |
I'v found this product http://soloshot.com/I would really like to understand the working behind this, the sensor used, and eventually making an arduino project. I cant get the working of the motion system, i think is a wifi radio system + what? Gps? Or a delay radio signal? IR is escluded of course. What do you think is the working behind this?
Airsoft Video Projects: [1]
« Reply #1 on: January 10, 2013, 10:41:16 am » |
As far as I know, they use 2.4GHz. So perhaps they use a gps in the transmitter, which is send to the receiver.
Since wifi and is also in the range of radar frequencies, they could use two receivers to get a direction. But I don't know if that is possible for a reasonable price.
If you're not living on the Edge, you're taking up too much space!
« Reply #2 on: January 10, 2013, 10:52:16 am » |
I would build one if it was less than $400! How do they do it?
If you fall... I'll be there for you! -Floor
Skype Brighteyes3333 (262) 696-9619
Massachusetts, USA
« Reply #3 on: January 10, 2013, 11:06:57 am » |
There are over 20 patents pending on the Soloshot technology. Perhaps if you could find those patents they would shed some light on the inner workings.
« Reply #4 on: January 10, 2013, 05:23:29 pm » |
Please will someone do this research? Do you know how to find the patents? I will read them if you Email them to me?
Massachusetts, USA
« Reply #5 on: January 10, 2013, 06:46:04 pm » |
I did some searches. No patent applications with the name Soloshot. No likely ones under the name Chris Boyle. Perhaps the company address would be the next thing to search for. http://appft.uspto.gov/
FROSINONE (FR)
« Reply #6 on: January 11, 2013, 09:45:46 am » |
Notthing found in europe either. BTW i tought it was a gps + wifi signal, but at that point i cant get the "content" of those 20 and more patent...so maybe is somethink different never used before?
If anyone has any ideas to achieve this working it would be cool.
I was thinking about a gps-like positioning system, two or more antennas and a delay signal interpolation to get the positive ( in front of the device ) position.
« Reply #7 on: January 11, 2013, 11:59:50 am » |
They say that the transmitter needs to be on for some minutes to be able to 'pair' it with the receiver. That is typical for a GPS receiver.
They also say it's range is 2000ft. It happens to be that a 1000mW wifi transmitter has a range of 2000ft (600 meters or so). But 1000mW 2.4GHz transmitter is forbidden in many countries. It also happens to be that there are 433MHz transmitters with a range of 2000ft. The antenna on the photo could be an antenna for 433MHz.
So it might be a GPS with a 433MHz transmitter. And the receiver has also GPS, to be able to calculate the position and angle. There is probably no need to send something back. So the transmitter is only transmitting and the receiver is only receiving.
I think you can find everything at Sparkfun.com It is going to cost about 200 to 300 dollars. But you need to program it, and they have already made a good looking receiver and waterproof transmitter. So you might as well buy the real thing.
« Reply #8 on: January 11, 2013, 01:27:47 pm » |
I don't think you need 2 GPS's. What if you start the single GPS at the base? Would that work?
I don't think it uses GPS at all. I believe it has to do with the timing or phase of 2 antennas.
« Reply #9 on: January 11, 2013, 01:47:12 pm » |
If the transmitter is held near the receiver/camera to initiate, only one GPS is needed. That is a good suggestion.
The photo of the receiver shows only one antenna. Using two antennes to calculate the delay between the receiving waves requires specific hardware and might cost thousand of dollars. Do you know an affordable application ? If a GPS is used, just normal standard hardware can be used.
UK
« Reply #10 on: January 11, 2013, 02:01:12 pm » |
There is an obvious antenna on the base unit which can only be used to communicate with the transponder. There is only one antenna and it looks like a non-directional antenna so I don't think there is any clever radio direction finding going on. This comment on the kickstarter page "Hey everyone- we designed SOLOSHOT with outdoor use in mind- the technology involved doesn't allow for indoor use." plus the fact you are recommended to be at least 50 meters away from the camera leave me certain that the system is based on GPS. I believe the transponder is essentially a GPS receiver plus radio transmitter and the base unit is a radio receiver, GPS receiver and compass.
« Reply #11 on: January 11, 2013, 02:28:35 pm » |
Great deduction Peter! I believe you may be right. I will build one.
« Reply #12 on: January 12, 2013, 12:59:50 am » |
After learning more I can see there is only 1 GPS and no magnetic compass. What if it could also do vertical tracking? Who would use it then? Which sports?
His is not very accurate when <200m away. What if I could make it work up close? Would this be valuable?
Off topic a little. You might see where I'm going. How accurately could I measure distance apart by measuring the time of a radio signal? The PPS pin of GPS has only 10ns jitter. I figure I can measure about 30-300m distance precision with only a TX and RX. Going one way that is, not round trip.
« Last Edit: January 12, 2013, 01:52:08 am by sbright33 »
UK
« Reply #13 on: January 12, 2013, 07:28:39 am » |
Are you sure there is no GPS or compass in the base unit? If not, I suppose it would be necessary for it to be given it's initial position by putting the transponder next to it and telling it to zero its position, and the operator would also need to tell it which way it was facing. I'd have thought a second GPS and compass would make it much more use friendly. However, maybe the cost would be prohibitive.
The radio direction finding based approach you're describing would potentially be a faster and more accurate solution, could be used indoors and would be better in many respects - but it would be *much* harder to get working IMO and would a lot of technological development. What Soloshot already does just needs a neat idea and some readily available technology brought together.
Massachusetts, USA
« Reply #14 on: January 12, 2013, 08:52:21 am » |
Where did you learn that? I'd be surprised if there was not a GPS in the base station because the difference between two nearby GPS fixes will be much more stable than a new GPS fix and a previous GPS fix. His is not very accurate when <200m away. What if I could make it work up close? Would this be valuable?
Yes, short distance would be useful. Indoor use would be useful. How accurately could I measure distance apart by measuring the time of a radio signal? The PPS pin of GPS has only 10ns jitter. I figure I can measure about 30-300m distance precision with only a TX and RX. Going one way that is, not round trip.
Light travels about 1 foot per nanosecond. With each end having 10-foot jitter I would think you would need a significant baseline (several meters) to triangulate a position.
