Topic: cable connectors (Read 660 times) previous topic - next topic
mrboni
Hi
Can anyone recommend some 4 way connectors that can take 5A and are as small as possible (and available in the uk)
Something like this - http://uk.farnell.com/multicomp/mc000066/plug-3-5mm-r-a-10a-04way/dp/2008039?Ntt=2008039 but with a female part too (neither should be pcb mount, both should be screw terminals or similar)
Thanks guys
Grumpy_Mike
Small and 5Amps do not go well together.
Quote
I am a bit confused by this. Do you want plug and sockets with a screw connection for the wire? Most plug and sockets have solder connections for the wire.
