Loading...
Pages: [1]   Go Down
Author Topic: Arduino IDE Serial Port Gray/Grey  (Read 551 times)
Offline Offline
Newbie
View Profile
I'm trying to use a Leonardo, and am trying to use the serial monitor for debugging, to make "trace" messages. When I click "Serial Monitor", it says the port is not found, and to change it in the Tools > Serial Port. Then, sometimes I can click it, sometimes I can't. When I can, nothing shows up (Programming?) When I can't, the menu is grey. Any help?
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
Two things
1) What OS?
2) Did you install the driver provided in the arduino software?
Logged
Offline Offline
Newbie
View Profile
1) Windows 7
2) The software has previously worked. The only thing is that I've gotten a new Arduino board. Wouldn't the driver be the same?
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
Thats a good question, since I down own a Leonardo, but glancing in the driver folders (of 1.0, bit outdated on this computer), there is one specifically marked Leonardo
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
What do you mean when you say you got a new board?
Did you have a uno (or any 328 based) board and then you got a Leonardo?  Or you had a Leonardo and got a new Leonardo?  Where did you buy the "new" board from?
Logged
www.cmiyc.com - A guide to being an Enginerd
Chile
Online Online
Edison Member
Arduino rocks
View Profile
WWW
If the problem happens on *some* times but not always, this probably will help you http://arduino.cc/forum/index.php/topic,118440.0.html
Logged
My homepage/blog: http://erwin.ried.cl
Offline Offline
Newbie
View Profile
I had a leonardo and got a new one.
Logged
Offline Offline
Newbie
View Profile
I've now found that my board shipped with dead pins. If there is a defect here, might there also be one in the serial communication portion?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Damage is damage.  Something happened to the board that shouldn't have, so I would call the whole thing suspect.
Logged
Pages: [1]   Go Up
Print
Jump to:
