Topic: Bluetooth module HC-06 (Read 668 times) previous topic - next topic
joeparsons
I bought a bluetooth module HC-06. I connect Vcc to 3.3v, GND to GND, tx to rx and rx to tx. in some tutorial on youtube someone uses two resistors, someone other connects it directly. I try both with and without resistors. then I change the serial port from 24 (the usb one) to 35 (the buetooth one). but the in the serial monitor nothing is printed. what is wrong?
thanks!
spycatcher2k
Forum howto : http://forum.arduino.cc/index.php?topic=148850.0
Read - Understand and Follow.
Drew.
http://www.uk-pcb.co.uk - My UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details. PM me for non repair or testing, 1 to 1 support and I will charge you - beware!
Nick_Pyner
You need to be a lot more forthcoming about what you are doing, exactly what HC-06 device you are using, and post the code, using the hash icon.
This is OK if, and only if, you are using the bare HC-06 module
Quote
Yes, hardware serial D0,D1
Quote
Good idea for Arduino Tx
Quote
This is unintelligible but it may be that the only thing wrong is that you are trying to use the serial monitor as a terminal. Make sure the USB cable is disconnected and use a proper terminal programme like RealTerm through a properly defined COM port.
You might find the following background notes useful
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
Robin2
I got one of these HC06 modules and I followed the wiring arrangements on one of the datasheets referenced at the bottom of the page.
As I understand it you should NOT connect the 5v Arduino Tx pin directly to the 3.3v Rx of the module. You can connect the 3.3v BT Tx to the Arduino Rx pin.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
