Loading...
Pages: [1]   Go Down
Author Topic: Sharp 20120x proximity sensor  (Read 242 times)
Offline Offline
Newbie
View Profile
Hello all!
I'm having a little bit of trouble with my current project that I'm working on.  I've written up the code for a simple bot that lights up in the dark and uses a proximity sensor to decide whether it goes forwards or turns.  Unfortunately, I'm having difficulty getting my proximity sensor to even display readouts, never mind function as I had anticipated.
I'm a little new to Arduino, and programming in general, and I can't seem to figure out if the problem is in my code or in my hardware.  I was hoping I could get some help, maybe a second pair of eyes from people who are more experienced, in order to find out what exactly I'm doing wrong.
Thank you very much!
My code so far:
int photoPin = A2; //selecting the input pin for the photoresistor
int photoValue = 0; //storing the value coming from the sensor
int whiteled = 4; //setting the white led to pin 4
int sensorPin = A1; //selecting the input pin for the proximity sensor
int sensorValue = 0; //storing the values coming from the sensor
int motor1Pin1 = 5;    // pin 2 on L293D
int motor1Pin2 = 6;    // pin 7 on L293D
int enablePin = 3;    // pin 1 on L293D
int motor2Pin2 = 10;   // pin 10 on L293D
int motor2Pin1 = 11;   // pin 15 on L293D
  pinMode(whiteled, OUTPUT); //the pin for the white LED is an output pin
  pinMode(photoPin, INPUT); //the sensor pin is an input
  pinMode(sensorPin, INPUT); //the sensor pin is an input
  pinMode(motor1Pin1, OUTPUT); //set motor pin as output
  pinMode(motor1Pin2, OUTPUT); //set motor pin as output
  pinMode(motor2Pin1, OUTPUT); //set motor pin as output
  pinMode(motor2Pin2, OUTPUT); //set motor pin as output
  pinMode(enablePin, OUTPUT); //set enable pin as output
 digitalWrite(enablePin, HIGH);
  sensorValue = analogRead(sensorPin);
  Serial.println(sensorValue);
  if (sensorValue < 600){
    digitalWrite(motor1Pin1, LOW);   // set pin 2 on L293D low
    digitalWrite(motor1Pin2, HIGH);  // set pin 7 on L293D high
    digitalWrite(motor2Pin1, HIGH);   // set pin 15 on L293D high
    digitalWrite(motor2Pin2, LOW);  // set pin 10 on L293D low
  else {
    digitalWrite(motor2Pin1, LOW);   // set pin 15 on L293D low
    digitalWrite(motor2Pin2, HIGH);  // set pin 10 on L293D high
  photoValue = analogRead(photoPin);
  if (photoValue < 5)
    float r = random(1000); //let the variable r be anything between 0-1000
    digitalWrite(whiteled, HIGH); //turn the light on
    delay(r);  // for random amount of time
    digitalWrite(whiteled, LOW); //turn the light off
    delay (r); //for a random amount of time
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
please use code tags when posting code, they are for free by pressing the # button above the smileys smiley-wink
You should first try a sketch that just reads the proximity sensor and outputs it value to serial. Then you get a better impression of the values it generates.
Can you tell what proximity sensor you use? link to datasheet?
Also post a schematic how you connected it, we cannot see it smiley-wink
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
