Topic: How to assemble this DIN-5 plug? (Read 957 times) previous topic - next topic
liuzengqiang
I purchased some of these DIN-5 plugs from digikey:
http://www.digikey.com/product-search/en?x=18&y=15&lang=en&site=us&KeyWords=CP-1050-ND
The two metal pieces in the picture come together to secure the center plastic piece with 5 pins. One metal piece has a place for strain relief. I try to assemble a plug but the two metal pieces won't stay together tightly enough and the plastic housing is soft so won't hold things together. The end result is useable but not nice enough. I wonder how these plugs should be assembled so they will be a one piece thing instead of the two metal pieces coming apart by a little. Thanks.
I'll get a better picture after lunch. My phone takes horrible pictures at close range.
liuzengqiang
BTW, the documentation says exactly what I was doing but the handle/housing is too soft to hold the metals tightly together:
http://www.cui.com/Product/Resource/DigiKeyPDF/SD.pdf
Maybe go with a different brand instead?
MarkT
Or use some insulating tape to bind the shells together and fill out the gap between them and the housing.
jackrae
Welcome to the world of cheap-and-nasty.
Something like this might better suit but there are even better ones out there.  Simply google 5-pin din plugs and a few variants will turn up
http://cpc.farnell.com/_/av19217/din-plug-midi-5p-metal/dp/AV19217?in_merch=Products%20From%20This%20Range
liuzengqiang
wow that screw on the side looks really nice and it is cheap. I'll limp on with the current parts I bought and the tape suggestion MarkT made and shop for better plugs.
kf2qd
Or put a couple layers of heat shrink tube on it. Doesn't rely on an adhesive so it is less mess if you have to take it apart later.
