Loading...
Pages: [1]   Go Down
Author Topic: 041, over... go ahead 041 over...  (Read 499 times)
0
Offline Offline
Full Member
View Profile
Ok, this is weird. So I built a microphone amplifier using the circuit from here:
http://www.rason.org/Projects/hbmic/hbmic.pdf
It works perfectly, except it picks up police radio? WTH is up with that? If you don't believe me, I've recorded a conversation here:
http://iluvtocnc.googlepages.com/test.mp3
Can anyone explain what's going on? It seems like I only hear the radio if the microphone is attached. And the microphone wire is acting like an antenna, since the audio quality changes if I move it around.
-Z-
Logged
Daniel
Guest
well you actually built a radio.. not weird at all.  smiley
Look at this circuit... look familiar?
A radio only needs three things:
- a tuned circuit ( the length of wire on your mic input and its capacitance makes a tuned circuit)
- a detector ( the diodes in the op-amp are the detector) and
- an amplifier with gain... that's the op-amp itself.
You'll find, sadly, that if you put a 1nf or 500pf capacitor from pin 2 to ground, your radio will die, but it'll work as a mic amplifer!
D
PS: try putting an aligator clip on pin 2 as an antenna, and you should get all kinds of stuff.
« Last Edit: September 05, 2007, 09:51:14 pm by Daniel » Logged
0
Offline Offline
Full Member
View Profile
Ah I see...
It must be some coincidence that it was tuned to the police frequency... I thought the police used more sophisticated radios, I guess not.
Thanks for the info!
-Z-
Logged
Pages: [1]   Go Up
Print
Jump to:
