Author Topic: Got a 4 digit LCD but...  (Read 274 times)
I had to buy it online as there is no electronics stores where I live.
The site where I bought the display does not show any description, brand or model about it.
So I'm a bit lost and wondering how to wire it  smiley-eek
The display is like this one
...but with 10 pins on each row.
Thanks in advance for any help
They are more difficult to drive than your typical lcds with controllers, as the mcu has to refresh the data constantly.
Your task #1 is to find the coms.
Melbourne, Australia
Shannon Member
Lua rocks!
I found a data sheet:
http://www.datasheet4u.net/datasheet/T/W/M/TWM259_Shenzhen.pdf.html
Not particularly informative, but it does give the pinouts.
Johannesburg UTC+2
@Nick I think OP meant it wasn't actually that model, but a 10-pin-per-side similar one
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Yes exactly, what Jimbo said.
No idea how to do it but I will start googling it.
Thank you.
« Last Edit: January 10, 2013, 03:31:57 pm by Rookie2 » Logged
Boston area, metrowest
Check the bottom, sometimes there is enough of a part number embedded to be able to find something.
Shannon Member
Lua rocks!
Oh I see. That picture had 20 pins per side.
Doesn't sound like a bargain if you have no idea how to use it.
If you are going to buy online (as I do) I suggest you buy something that has Arduino support. Stuff like the displays from Adafruit, Sparkfun, etc.
Use your arduino to generate a (roughly) 100hz signal. Take the GND (or VCC) pin and the signal pin, and apply them to any two pins on the lcd.
As you slide around the signal pin, and see lots of segment liting up, the GND pin is on a com.
Thank you. Luckily I managed to get the datasheet from the store!
Topsham, Vermont USA
Online Online
... in The Woods In Vermont
Let us know how it works out...
If you get to feel it's too much trouble and way too many pins to control, think about only 2 pins on an I2C controlled display like these:
http://arduino-info.wikispaces.com/LCD-Blue-I2C
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Those are quite different animals.
