Topic: Wrong sketch? (Read 2708 times) previous topic - next topic
robyr1
hi to all! i have an ArduinoUNO, and i tried to use this sketch, but it wont work!! why??
* WiiChuckDemo --
* 2008 Tod E. Kurt, http://thingm.com/
#include <Wire.h>
#include "nunchuck_funcs.h"
#include <Servo.h>
Servo olhosim;
Servo olhonao;
Servo boca;
int valorolhosim = 0;
int valorolhonao = 0;
int valorboca = 0;
int loop_cnt=0;
byte accx,accy,accz,zbut,cbut,joyx,joyy;
int ledPin = 13;
olhosim.attach(8);
olhonao.attach(9);
boca.attach(10);
    Serial.begin(19200);
    nunchuck_setpowerpins();
    nunchuck_init(); // send the initilization handshake
    Serial.print("WiiChuckDemo ready\n");
    if( loop_cnt > 100 ) { // a cada 100ms, pegue novos dados
        loop_cnt = 0;
        nunchuck_get_data();
olhosim.write(valorolhosim);
delay(1);
olhonao.write(valorolhonao);
delay(1);
boca.write(valorboca);
        accx  = nunchuck_accelx();
        accy  = nunchuck_accely();
        accz  = nunchuck_accelz();
        zbut  = nunchuck_zbutton();
        cbut  = nunchuck_cbutton();
        joyy  =  nunchuck_joyy();
        joyx  =  nunchuck_joyx();
valorolhosim = map(joyy, 0, 250, 0, 179);
delay (1);
valorolhonao = map(joyx, 0, 250, 0, 179);
delay (1);
valorboca = map(accy, 0, 150, 0, 179);
delay (1);
        Serial.print("accx: "); Serial.print((byte)accx,DEC);
        Serial.print("\taccy: "); Serial.print((byte)accy,DEC);
        Serial.print("\taccz: "); Serial.println((byte)accz,DEC);
        Serial.print("\tzbut: "); Serial.print((byte)zbut,DEC);
        Serial.print("\tcbut: "); Serial.print((byte)cbut,DEC);
        Serial.print("\tjoyx: "); Serial.print((byte)joyx,DEC);
        Serial.print("\tjoyy: "); Serial.print((byte)joyy,DEC);
        Serial.print("\valorolhosim: ");Serial.print((byte) valorolhosim,DEC);
        Serial.print("\valorolhonao: ");Serial.print((byte) valorolhonao,DEC);
    loop_cnt++;
    delay(1);
AWOL
Usual questions - what does it do that it should not, and what does it not do that it should?
Please use code tags when posting code.
if( loop_cnt > 100 ) { // a cada 100ms, pegue novos dados explain, please.
robyr1
wow!
ok, i have an arduinoUNO, and i need to control 2 servos with my wii nunchuck. I found this sketch, but i'm not able to load on my board, any suggest?
AWOL
If it won't load, it is fairly obvious that it cannot work, but you didn't say that.
What error message do you get when you try to upload?
robyr1
here are the message: "nunchuck_setpowerpins was not declared on this scope
lollotek
just try to save this file in the same folder where you have your sketch, then close and reload
https://raw.github.com/todbot/wiichuck_adapter/master/firmware/WiichuckDemo/nunchuck_funcs.h
tpa10
to reinforce the previous poster's message:  you are getting this error because you trying to call a function that hasn't been defined or declared...
Set the "verbose" option in the IDE and look at the output, you will very likely see that the compiler is complaining at you about not being able to find the include file.
